Marine Y-Block Find !
Discussion in 'The Hokey Ass Message Board' started by 41 Dave, Jul 23, 2006.
  1. 41 Dave
    41 Dave
    Guys, Just had an awesome find for my Model "A' ! How about a complete (and running - when removed from the boat it was in !) Marine Y-Block Ford. I mean complete from the aluminum oil pan to the aluminum two carb intake(side draft Carter carbs. It is complete with all linkage, fuel lines and even air cleaners ! You look inside the valve covers and it is clean like a fresh low time motor. The only issue might be that it rotates the opposite direction. Don't know yet - but the first thing I will do when I get it home is to fire it up to see how it runs ! I will include pix when I get it home. May need help to get them sized properly.
    41 Dave :)
  2. Bob K
    Bob K
    from Antigo Wi.
    Keep us posted on this one please, I'd love to see some pics
    B:eek:B
  3. tommy
    tommy
    My dad had a 1964 Pearson cruiser with twin screw Y blocks exactly as you discribe. I have seen a hot rod with that intake system. I can't remember how he adapted the cooling system. I always thought it was a cool system.
  4. 41 Dave
    41 Dave
    Guys, Thanks for the response. I will try to keep you up to date. The mill is going in a '31 "A" Coupe mounted on one of Bleed's "Danger-Danger" frames.
    41 Dave
  5. Gotgas
    Gotgas
    from DFW USA
    Will a cam swap (and starter?) correct the rotation?
    Awesome score! 292 or 312 or do you know?
  6. Pics Please. You will have a cooling problem with that intake.
  7. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    A cam swap and starter will fix the rotation issue. I have seen intakes machined to accept a thermo housing and way to hook up the radiator..EVILT
  8. 41 Dave
    41 Dave
    Guys, I guess the whole cooling issue is based on the fact that the water jackets are not a part of the intake. Is this a big issue. If there is no hot water for the intake - does it effect the cooling of the intake charge ? I know these intakes sure go fast on EBAY. Would this effect the running of this motor with a radiator and water pump ?
    41 Dave
  9. Run a banjo rearend with the banjo upside-down (drain plug on top) and you won't have to reverse the engine rotation. :D
  10. Michigander
    Michigander
    I don't know about the Y-block specifically, but the Ford FE was from the same era and it requires some work to the crankshaft to change rotation. On the FE, there are a series of very light 'scratches' on the crank surface where the rear main seal rides. They are used to keep the oil inside the crankcase, oil that gets under the rope seal. If the crank is rotated in the opposite rotation, it will pump oil out of the crankcase! To fix this (on a FE), that surface needs to be polished enough to remove those marks. Then, use a neoprene rear seal instead of a rope seal to complete the swap.
    Steve
  11. old beet
    old beet
    When I was in school some friends did that on accident!!! 1 gear forward and 3 reverse.. Think it was a 46 Ford....OLDBEET
  12. Dave Downs
    Dave Downs
    from S.E. Penna
    RE: reverse rotation; it's possible to 'flip' the pumpkin in some open drivelines also - but I don't know which ones other than a 'shoebox' Ford 'cause I saw that done by accident................
  13. Dale Fairfax
    Dale Fairfax
    A guy named Dennis Frings from down in the Carolinas has been running a marine manifold on his Y-Block track style roadster for quite some time. The car has been pictured in the G.G.Gazette and in R&C. While I didn't pay particular attention to how he handled the cooling, it's been addressed on Lon Wrens radical roadster here in Indy. He found a 6 X 2 manifold that had no water connectionss. We drilled and tapped the front of each head for 3/4 NPT and installed two connectors and hoses to a remote fill/thermostat housing with a single outlet to the radiator. Works like a champ.
  14. I have a complete marine set up for a flathead Ford that I want to get rid of. Br*** pulleys, bronze, copper, all kinds of neat stuff. It comes with a transmission too. It is up here on Vancouver Island. The shipping will be pricey as that trans weighs a ton.
    email me...jarvis1@shaw.ca
  15. ibcalaveras
    ibcalaveras
    I never heard of that.. I have a 56 Y-block in a 17' Crooks wood boat, I was thinking of doing the same thing for my A coupe. How can you tell if it is counter-rotating engine? Donn
  16. SimonSez
    SimonSez
    The counter-rotating setup is generally only used when there are two engines in a boat, and even then it is only one of them.
    It is pretty unlikely that a single engine installation will be counter-rotating.
  17. 41 Dave
    41 Dave
    Guys, I really appreciate all the feedback. I am kind of up in the air as I have a good running '56 truck motor. Would really like to run this Marine Y block. I need some further thoughts or photos on how to do the water hook ups.
    41 Dave
  18. tommy
    tommy
    I just copied this from the Y block performance thread. This is how one hot rodder got around the cooling system problem. It should work for the marine manifold as well.
  19. zootkandy
    zootkandy
    That's my pop's roadster. Refer to Dale Fairfax's post...
  20. Aman
    Aman
    from Texas
    Are you sure the motor runs in reverse? That's a new one. Usually the counter rotating prop has a transmission that reverse the rotation. The motors should be the same.
  21. revkev6
    revkev6
    from ma
    don't know about the marine Y-block but my father owned a 71 correct craft separator V-drive that was setup Reverse rotation. it had a holman moody 351 in it. very rare boat. they had it reverse rotation because of a balance problem. supposedly if the rotation was normal, with just the weight of the drive in the boat taking a hard turn at speed would flip it.
  22. SimonSez
    SimonSez
  23. mgudge
    mgudge
    from Orygun
    I could be intersted in the flathead marine set up and could drive up and pick it up, call me 503-622-3639 or email fordhavenzigzag@msn.com, thanks Mike
  24. MP&C
    MP&C
    41 Dave, I think You'll need to change the cam, distributor drive gear, and firing order to match the automotive cam. Here's a link for you to check out, notice in the picture there are separate castings for the water necks on each head....
    http://www3.nbnet.nb.ca/khan/jetsite/intrcept.htm
  25. 56don
    56don
    Did you not notice that this thread is 4 years old?? I doubt you will get a response on the flathead stuff now.
  26. Jagman
    Jagman
    I worked on boats back in the 60's and one of my customers had a Chris Craft with twin Fords, I found out the hard way that one of them ran in reverse when I put new plug wires on both motors and one ran fine and the other..................well, didn't! :rolleyes:
    They did this to help with the steering, if both engines turned the same way the torque would make it almost impossible to turn the boat one direction, plus you'd have to be leaning on the wheel all the time just to go straight.
    Running them counter (airplanes do this too) makes it very neutral, as long as the engines are running approximately the same speed.
  27. kool32
    kool32
    from Kentucky
  28. 41 Dave
    41 Dave
    kool32, Those are some cool Y Block pix you posted. Are any of them in your rod ?
  29. That's the coolest Y Block i've ever seen !!!!!
  30. paco
    paco
    from Atlanta
    So ..... 41 Dave ...... Any progress?? Are you going to run it?
    Very kewl looking engine/intake/carb combo. Nice pix kool32 - thankx.
    PACO
