Projects Martin Ford´32 5 Window Build
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Aug 29, 2011.
  1. gbones32coupe
    gbones32coupe
    cars looking great!
  2. tmfcracing
    tmfcracing
    from Sweden
    It,s a lot of money spent but as I see it , I want a car that runs good and dont take that much gas as the gas price is dubble up in Sweden. I belive the atomic will give a better gas per milage compared to a carb and therefor i'll might get the money back in time.
  3. 32 steel
    32 steel
    nice car real cool great work
  4. jefscoupe
    jefscoupe
    Yeah, I forgot how much gas costs over there.:eek:
    Are you running an MSD dizzy/box as well?
  5. tmfcracing
    tmfcracing
    from Sweden
    I will have a 6al box.
    Today I make a cut out in the air cleaner for the dist .
  6. tmfcracing
    tmfcracing
    from Sweden
    I left the hairpins to a friend who put them in some kind of acid to get the crome off and today I got them back. Powder coated semi gloss black, sooo much better :)
    brEad likes this.
  7. tmfcracing
    tmfcracing
    from Sweden
    Tomas who is the painter sendt a pic of the taillight bezel that I made out of aluminum.
    Everyting that normaly is shiny on the body as handles, window frame mirror and such things will be painted instead.
    brEad likes this.
  8. 55bird
    55bird
    from Spokane WA
    Whew! You do beautiful work!
  9. Crashhead
    Crashhead
    Martin oh Martin...this will be another killer hot rod you build. Love it! Looking awesome...
  10. tmfcracing
    tmfcracing
    from Sweden
    Thanks, today I made a gas pedal . I was about to use a vintage drum pedal but it feelt to big.
  11. tmfcracing
    tmfcracing
    from Sweden
    .....and grinded/rounded .
    kiwijeff likes this.
  12. n847
    n847
    wow...looks great!
  13. 57tailgater
    57tailgater
    from Georgia
    Awesome pedal ***embly. Can we see how you did the bearings and lever attachment? Thanks! :cool:
  14. tmfcracing
    tmfcracing
    from Sweden
    Very simple, used the lathe to get a skateboard bearing fit on each side. The lever sits on the bolt only and the outside tube does not move.
  15. tmfcracing
    tmfcracing
    from Sweden
    Outside firewall .
  16. tmfcracing
    tmfcracing
    from Sweden
  17. Inland empire hot rods
    from so cal
    awesome pedal ***embly!!
  18. tmfcracing
    tmfcracing
    from Sweden
    I have also started to mount the electrical components behind the dash.
  19. Martin, awesome build - one of my faves and such an influence that I had to go find an Adler grille shell - I've got an NOS one currently on it's way from Germany!
    A question about your built throttle pedal, how do you get the consistent radius on the ground brackets? Are these ground down by hand or do you have a tool that will radius the plate steel?
    Steve
  20. tomkelly88
    tomkelly88
    Very neat, I'm loving this build and I wish you'd post more often!
    Are you going to use this plate to mount something on the fire wall? Will it look odd sitting there by itself?
  21. tmfcracing
    tmfcracing
    from Sweden
    Glad to here that you liked the Adler grille .
    Nice that you find a grille, i dont think they grow on trees so to speak.
    The rounded edges make the parts feeling 46 years older then they really are.
    I do it by hand with a normal grinding machine. Its the "feeling" in you hands that is the deal.
    On normal steel I go with 80 and then 240 grid and at last the sisal .
    If you want the edge stainless go 80,120,240,320 and sisal.
  22. jefscoupe
    jefscoupe
    It takes a good eye, feel and practice to get an edge radius that smooth and even.
    Good work Martin. I hate the square, band sawed look of the billet stuff too.
    What are you going to use for the pedal itself?
    For Steve's question:
    That can be done with a corner-rounding endmill, but following the curvy profile would be a pain to do without a CNC.
    For those that know and have access to CNC equipment, you would program using the small diameter of the cutter- eg 1/4 stock use 1/8 CR tool- with the depth of cut being the radius or a little less, then adjust TLO to get full radius. RPM would be calculated using the largest diameter of the cutter.
    Those who don't know CNC, sorry for the gibberish. :rolleyes:
    It could be done with a rotary table on a manual mill, but very time consuming. Each radius on the profile would have to be set up, indicated in and then cut...on both sides of each piece = hours.
    Martin probably did all that in about 30 minutes or less.
    Typical corner rounding endmill:
    Typical rotary table
  23. jefscoupe
    jefscoupe
    Ah HA! I finally get to see how you did that brace under the dash.
    :cool:
    brEad likes this.
  24. tmfcracing
    tmfcracing
    from Sweden
    Thanks Tom, and I wish I was faster in the shop and had something interesting to post more often ;)
    The plate is a outside washer in stainless steel for the gas pedal. It will be painted in the same color as the firewall and I belive it is goin to "melt" in better when painted.
    Cheers
  25. tmfcracing
    tmfcracing
    from Sweden
    I dont know yet what to do with the pedals, both brake and gas. I probably make some models for it and sandcast it in aluminum.....I have to think about it ;)
    I forgot to show the pic of the drop bracket, better late then ever ;)
    The reason why it has one rounded side is to make clearence for the most left-hand gauge.
  26. tmfcracing
    tmfcracing
    from Sweden
    I have been scratching my head for some days about were to have the needed start key, light****ons and such things.
    So this last saturday I started with a hitech drawing that is the lower line of the dash.
  27. tmfcracing
    tmfcracing
    from Sweden
    And then I rewrite it in to the pc. Extremly traditional as I am ;)
  28. tmfcracing
    tmfcracing
    from Sweden
    I do understand that you guys right now think that this will turn out to some billet boyd **** :)
    .......but hold on. Were not done yet !
  29. tmfcracing
    tmfcracing
    from Sweden
    Here is how the complete drawing looks like .
  30. tmfcracing
    tmfcracing
    from Sweden
    First part that will be up front
