Projects Martin Ford´32 5 Window Build
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Aug 29, 2011.
  1. tmfcracing
    tmfcracing
    from Sweden
    Thanks for your kind comments guy's :)
    This is how the reg holder turned out.
    Backside
  2. tmfcracing
    tmfcracing
    from Sweden
    Frontside
    kiwijeff likes this.
  3. tmfcracing
    tmfcracing
    from Sweden
  4. tmfcracing
    tmfcracing
    from Sweden
  5. davo461
    davo461
  6. n847
    n847
  7. Crashhead
    Crashhead
    You need to start selling these killer products my friend!
  8. tmfcracing
    tmfcracing
    from Sweden
    Thanks mates :)
    Found a trashed p***enger door lock hole underneth some lead yesterday so I made a tool to get the right resess on the new hole.
  9. tmfcracing
    tmfcracing
    from Sweden
  10. tmfcracing
    tmfcracing
    from Sweden
    The right hand side part is the one that will end up in the door, the other parts is for the resess tool.
  11. tmfcracing
    tmfcracing
    from Sweden
    All together and the sheetmetal that gets the resess id in the middle
    Used the bench vise to press it.
  12. tmfcracing
    tmfcracing
    from Sweden
    Here it is, made the hole in the waterjet.
    Now it just needs to be welded into the door.
  13. ESGEE
    ESGEE
    from Sweden
    Really enjoy seeing your farication of things, keep the great work up...
  14. tmfcracing
    tmfcracing
    from Sweden
    Trying to Esgee ;)
    Next step , get it in place .
  15. jefscoupe
    jefscoupe
    You like that water jet just a little too much. :D
    Great work Martin.
  16. tmfcracing
    tmfcracing
    from Sweden
    I know, it gone so far that I use the jet instead of a drill sometimes. I need major rehab !!!! . Hahaha
    Addict as I am, here it is :)
  17. DaddyO's..Deuce
    DaddyO's..Deuce
    from Missery
    Every time I think I've seen it all, you just continue to blow me away!
  18. rcnut223
    rcnut223
    from wisconsin
    Your at it again, really nice work.
  19. rottenleonard
    rottenleonard
    Check out Limeworks ad in the new street rodder, his brake and shift handles are available.
  20. redzula
    redzula
    I was wondering if that was his or a knock off. Pretty cool
    Nice work on the lock hole. Lots of work for such a small overlooked part lol looks good regardless
  21. tmfcracing
    tmfcracing
    from Sweden
    Today I did a new floor center section that is to be over the trans, I wanted it to be removeable and the thing I did 2 years ago looks totaly ugly.
    First thing I did was a 1" square frame that will be welded into the floor. Next thing was the "lid" that has a cone made in the english wheel.
    Later on there will also be a aluminum frame that is around the cone and holds the carpet in place.thats why there is holes around it.
  22. tmfcracing
    tmfcracing
    from Sweden
  23. tmfcracing
    tmfcracing
    from Sweden
  24. tmfcracing
    tmfcracing
    from Sweden
  25. Tnomoldw
    Tnomoldw
    :)That is cool! :cool:hmm but it seems like overkill =lots of screwen :eek:. doh:rolleyes:, maybe not you are looking directly at it.;) Stainless screws?
    I saw a tech way of bolting floor panels down. You may want to use it some where ,sometime.= short piece(3/8 to 1/2 inch tall) of tube or round stock with a hole in it ,threaded and countersunk , tack weld in place , when the cover panel is attached the screw /bolt creates a depression into the counter sunk hole. When tight the top of the screw/bolt is flush. :D
  26. tmfcracing
    tmfcracing
    from Sweden
    Might be a lot of screws, rather too many then to less and i think the panel
    wont be removed so often.
    The panel holes is countersunk and the screws will be flat and hidden under the carpet.
    The only visable screws is the once around the cone that holds the aluminum frame.
    Anyway, you tech way sounds like a really good one :)
  27. Tnomoldw
    Tnomoldw
    :)Here are pics;):cool::eek:
  28. tmfcracing
    tmfcracing
    from Sweden
    I like the countersunk rod thing, but how floppy will the panel sheet be between the rods. And it is goin to be like a big "dirt pocket" were they are.
    Maybe a good one would be the same thing but have the countersunk rods underneth a sheet with holes instead of being on top of the edge.........hmmm, I need to think ;)
    Thanks for the advise.
  29. farmer12
    farmer12
    Awesome work. I honestly can't believe I've missed this thread.......Keep up the great job you're doing. I've subscribed, so I won't miss it anymore!
  30. Tnomoldw
    Tnomoldw
    I wondered that too ,but after looking at it a few minutes I believe the bolted down panel over laps the higher edge which means the tubes are the same level or a few thousandths lower than the highest part. :eek: I idea is cool but maybe you can find a better use for it. It reminds me of a hatch/door retainer system,
