Projects Martin Ford´32 5 Window Build
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Aug 29, 2011.
  1. mace69
    mace69
    from mass
    x2!
  2. slepe67
    slepe67
    jeez, I can't even drill out accurately aligned holes in sheetmetal...and I look at the stuff you build.
    I'm speechless at the work you're doing!
  3. tmfcracing
    tmfcracing
    from Sweden
    When the e-brake is done the next thing will be a shifter, goin to suit your new ride perfectly. That car is awsome :)........and you are not allowed to sell it !!!!!
    Think I will only make a shifter-rod that works for a lokar mecanism.
  4. tmfcracing
    tmfcracing
    from Sweden
    Thanks guys for all the comments :)
    Hey slepy, I can,t do that too. You know im cheeting, im running a waterjet for a living and that makes things a lot more easy.
    Next thing you will do after reading this is to google "Draftsight cad".
    It is a free 2d cad program simular to autocad, it is easy to learn and there
    is even lessons on youtube for it.
    When you learn how to draw you can mail your drawings to your local water/lazer cutter.
    Please take the time it takes to learn this, You will thank me for this advise ;)
    Edit: I just made a tread about it.
    http://www.jalopyjournal.com/forum/showthread.php?t=653349
  5. langy
    langy
    I have those very mufflers on my 32 roadster and they sound nice.
  6. tmfcracing
    tmfcracing
    from Sweden
  7. Crashhead
    Crashhead
    Haha, we'll see...Worked on it today and hope to have it running til the summer...
  8. tmfcracing
    tmfcracing
    from Sweden
    Did the final welding and some grinding on the new airvent today, the original one was welded all the way around.
  9. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    ^^^^Wow what an aweful job welding in the cowl vent, you can't even see the weld! I'd be pissed :D:D:D:D.^^^^^
  10. tmfcracing
    tmfcracing
    from Sweden
    Merry Cristmas to you folks :)
  11. juniorsrodshop
    juniorsrodshop
    from nh
    lookin good.. way better than when you got it!
  12. Simple.
    Simple.
    from Troy, MI
    Wow, there is so much inspiration in this thread! Keep up the good work, cant wait to get back in the garage after the holidays and continue my projects!
    Jon
  13. tmfcracing
    tmfcracing
    from Sweden
    Worked on the trunk lid the other day, this pic shows the place were
    the latch is supposed to be located. Pretty beaten .
  14. tmfcracing
    tmfcracing
    from Sweden
    Made the new sheet , I think my new latch might be made for rumble style and I will
    have to mill it down to fit.
  15. tmfcracing
    tmfcracing
    from Sweden
    I sheated, there should be a dip around the latch bolt. I made the hole bigger to let the wrench fit instead. The handel thread/nut will be on the inside.
  16. alchemy
    alchemy
    I think you mean you "cheated". Your work doesn't look like sheat at all.
  17. tmfcracing
    tmfcracing
    from Sweden
    Ops, your are right :).
    I,m glad I didn't wrote "I ****ted myself" or something ;)
  18. slepe67
    slepe67
    :Dthat would be "I shat myself!" I'm joking man and I know you were too. You speak better English than many Americans!
    The trunklid looks great.
    As far as cheating goes, dude, you can't even tell. Maybe the Pebble Beach guys might be able to, but I can't and am really enjoying this build. Craftsmanship is bar none. Go man go!
  19. tmfcracing
    tmfcracing
    from Sweden
    While dealing with the trunk I decided to solve the hinge issue.
    The original holes are more square then round after all years and
    even if I take care of them the trunk wont be adjustable.
    I read about an old fart saying that there is no pride making parts with modern
    machines so thats exactly what I want to do , some hi-tech **** ;).............again.
    Started with some drawings , a great thing here is that it,s possible to rotate the hinge
    and see how many degrees it can move.
  20. tmfcracing
    tmfcracing
    from Sweden
    Cutted the parts out.
  21. tmfcracing
    tmfcracing
    from Sweden
    I use this little stone table called "diabas" when welding to get things strait.
    kiwijeff likes this.
  22. tmfcracing
    tmfcracing
    from Sweden
    The long rod is nice to get the hinges in line with each other while mounting, later there will be normal bolts.
  23. tmfcracing
    tmfcracing
    from Sweden
    One open and one closed. They look a lot bigger on the pics then what they really are.
  24. Salt Flats Speed Shop
    from Utah
    Love those hinges! Nice work!
  25. langy
    langy
    Nice job Martin, I've just done the same job on a 3W
  26. tmfcracing
    tmfcracing
    from Sweden
    I resently ordered the panel below the trunklid that is made of United Pacific Industries. It is complete with all the inside parts just as original. Hope its as good as it looks .
  27. tmfcracing
    tmfcracing
    from Sweden
    Steve, is the 3 window yours ?
  28. nailhead terry
    nailhead terry
    I bought one of their panels it fit great helped in line up
  29. Tudor
    Tudor
    from GA
    wow! nice work - I just put bolts back in the holes to hing the top of the lid. hope those hinges don't hit other stuff. My stuff is tight back there. That's the difference in haulin *** and looking good.
  30. Crashhead
    Crashhead
    Keep it up buddy!! Looking forward to stop by in about a month and a half and ******** with ya!! Happy New Years!
