Projects Martin/Larsen Ford '32 frame build
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Jun 13, 2013.
  1. brady1929
    brady1929
    Very cool Martin
  2. tmfcracing
    tmfcracing
    from Sweden
    Thanks Gbrown, yes I did the jig by my self. Best thing with it is that I can hook it up to a car and take it for a ride (in case I for some strange reason wants to ;)
    Glad you like it , lets hope it turn's out super :)
    Brady , you should become a Cheerleader ;) thanks a lot mate !!!
  3. Pewsplace
    Pewsplace
    Now that is a piece of work. Are you using a stock (curved) or 40 (straight) spring? You must have some serious break to bend that 3/16 plate.
  4. brady1929
    brady1929
    No Martin, just jealous of your skills. Ha Ha
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I 'll be your cheerleader along with Brady,.. Martin.. you have mad skills!!!... Very very nice work...so clean!!
  6. .
    Damn, you guys don't kid around! Nice work.
  7. Larsa2000
    Larsa2000
    from Sweden
    Rear crossmember in place (just tacked for now). The last welding of the box plates have also been done, so now its time to get the rear axel in place and start with the x-member.
  8. Larsa2000
    Larsa2000
    from Sweden
    (The picture didn't upload in the post....)
  9. Larsa2000
    Larsa2000
    from Sweden
    Some rivets for the right look.... ImageUploadedByH.A.M.B.1383238555.332121.jpg ImageUploadedByH.A.M.B.1383238575.817194.jpg
  10. tmfcracing
    tmfcracing
    from Sweden
    Were glad you guys like it :)
    Check this little friend out. Todays add to the shop, a Esab ac/dc pulse tig.
    Not trad at all but I still love it !!!
  11. nailhead terry
    nailhead terry
    That ****er is gonna be low in the rear I had to raise my 5 window 2'' but that was a 32 spring and c notches in stock rails with a flatened rear 32 cross member I guess we are in the same club my ch***is jig has a removable axle where I can push it out becase it takes up to much room and a trailer tounge where my buddies can use it !!
  12. ESGEE
    ESGEE
    from Sweden
    Great metal work, cant wait for the next update...
  13. Larsa2000
    Larsa2000
    from Sweden
    Rear axle tacked in place and ladder bars being mounted. The shape of the x-member cut in cardboard, time to start working on it.
  14. weldtoride
    weldtoride
    Great thread, just subscribed. Thanks for taking the time to post.
  15. Larsa2000
    Larsa2000
    from Sweden
    X-member in peaces, cut in water jet. The large holes are for the exhaust.
  16. Larsa2000
    Larsa2000
    from Sweden
    First side well on the way...
  17. Bulletnose26
    Bulletnose26
  18. rory_a
    rory_a
    from Sparks, NV
    Awesome looking ch***is so far! Love the frame jig too, keeps the frame work straight and true.
  19. Pewsplace
    Pewsplace
    Yes, you have a great start on your ch***is. New ideas and excellent craftsmanship make this thread worth following.
  20. tmfcracing
    tmfcracing
    from Sweden
    Thanks a lot Guy's.
    Here is the way I do for welding box plates and other ch***is parts.
    The pics shows the 3mm x-member.
    When tacking I put the plates inside edge to inside edge and get a L-shape and thats ofcorse is where the weld will go.
  21. tmfcracing
    tmfcracing
    from Sweden
    When welding I'll get a radius for free :)
  22. tmfcracing
    tmfcracing
    from Sweden
    The point with this method is that there is very little grinding needed and the weld is still there.
    Othervise when welding a thin spring and then grinding radius you will end up with cracked parts.
    My english ****s big time but I hope you guys understand.
  23. tmfcracing
    tmfcracing
    from Sweden
  24. CW's40TPU
    CW's40TPU
    Wow....very nice!!!!!!
  25. Pewsplace
    Pewsplace
    Nice idea and should be strong.
  26. alchemy
    alchemy
    What do you do to the inside of the joint? I would think a little of the bead would bubble through on the inside. Do you run a bead inside as well, or just grind the bits that pop through?
  27. stealthcruiser
    stealthcruiser
    Nice, Nice, Nice!
    You're English is better than mine!
  28. tmfcracing
    tmfcracing
    from Sweden
    Exactly Alchemy.
    Grind the inside off and making a small radius with bondo before paint.
  29. brady1929
    brady1929
    Beautiful work guys
  30. tmfcracing
    tmfcracing
    from Sweden
    Thanks Brady.
    Things getting forward slowly . Started on the centersection for the x-member.
    Made a press tool for the top plate , the material is 3mm thick so it needed loads of pre***ure tho press it.
