Technical Marvel mystery oil inverse oiler
Discussion in 'The Hokey Ass Message Board' started by paintslinger805, Feb 10, 2017.
  1. image.jpg image.jpg image.jpg image.jpg How many of you guys have ever used or seen one if these. Please give some story as to where what and why you ever used one. Pretty neat.
    kidcampbell71, Jet96, Stogy and 2 others like this.
  2. donno21
    donno21
    Stogy and loudbang like this.
  3. woodbutcher
    woodbutcher
    :D Looks like fun.
    Good luck.Have fun.Be safe.
    Leo
    Stogy likes this.
  4. rustydusty
    rustydusty
    It's interesting, but I would think that running oil into your intake would cause the car to smoke. Like running 2-cycle fuel.
  5. Chaz
    Chaz
    Remember pouring STP down your carb?
    Stogy, Andamo and loudbang like this.
  6. Jack E/NJ
    Jack E/NJ
    from NJ
    Easier to add MMO to gas tank. Jack E/NJ
    Stogy likes this.
  7. Montana1
    Montana1
    I found one at a swap meet years ago. Paid 5 bucks and put it on the shelf in the storage shed. Mine has a gl*** jar and a "G" type adapter with it. I think it's cool, but never used it.
    If I use MMO I usually just pour a few oz. in the gas tank as needed, or pour it down the carb while running for storage to prevent stuck valves and rings. I have put it in the crankcase to free up sticky lifters.
  8. Rusty O'Toole
    Rusty O'Toole
    "Inverse" means it works backwards to the intake vacuum, feeding more oil at low vacuum and less at high vacuum. So the engine gets more oil when working hard and less when idling or cruising.
    They were supposed to keep the combustion chamber clean and reduce wear on valves, valve guides, rings and pistons, doubling engine life between overhauls.
    A cool "vintage" accessory, and could save your engine.
    ClayMart, Stogy, loudbang and 2 others like this.
  9. Road Duster
    Road Duster
    Back in the late 60's I stopped by the plant in port chester n.y.. My uncle Al was the manager in charge. He ran the Co .He said pull the car in. Which I did, he then instilled the Marvel Oiler, and put the car on the dino. The oiler work great . My car at the time was a custom 1955 Buick.
  10. woodbutcher
    woodbutcher
    :D Those oilers that I saw were mostly on marine applications with the flat head Chrysler I6`s.The reason that I was given was that that particular engine was pretty prone to have the valves and/or lifters stick if they were`nt used on a regular basis.From what I was told by owners of those engines in a marine use setup,that oiler pretty much eliminated the problem.Other than the sticky valve/lifter deal they were a pretty darn good marine engine.
    Leo
    ClayMart, Stogy and loudbang like this.
  11. Anyone else have any memories??
  12. lonestar395
    lonestar395
    from Australia
    My brother had one or similar with the Judson supercharger, probably saves the vanes, don't recall the oil he used...
    seb fontana, Stogy and loudbang like this.
  13. Truck64
    Truck64
    from Ioway
    Can still buy the Ampco oilers. I think they look kinda neat. Not $70 neat, + shipping and handling though. The way I heard it, all of them for sale today are NOS left over from the 50s or whatever, somebody found a warehouse full of them and marketing them.
    Maybe it's todays gasoline, but running 4 oz per 10 gallons of fuel swear old iron runs noticeably smoother. Maybe ATF or diesel would do the same thing I dunno. I don't drive the old beast as often as I should and usually not in the winter, so it seems like cheap insurance for sticky valves, lifters, rings, ethanol on rubber etc.
  14. Truck64
    Truck64
    from Ioway
    Heck no, I don't! That **** doesn't even pour near as I can tell. Well hardly. I bought a can of it the first time about six months ago, to use in a manual steering gearbox. It doesn't leak out. Can't imagine running it in a motor. Whatever works I guess.
    Stogy likes this.
  15. crminal
    crminal
    That's cool. Didn't know they made such things. As others have said, "I just put it in the tank".
    Stogy likes this.
  16. i.rant
    i.rant
    Learn something everyday, cool piece. I'm still pouring in the tank.
    Stogy likes this.
  17. Jimbo17
    Jimbo17
    I have used Marvel Mystery oil for years for one simple reason. IT WORKS !!!
    Jimbo
    kidcampbell71 and Stogy like this.
  18. Barn Find
    Barn Find
    from Missouri
  19. seb fontana
    seb fontana
    from ct
    Yes, for the vanes..Doesn't take much..
  20. pumpman
    pumpman
    Not Marvel but the Whiz version. IMG_0093.JPG IMG_0093.JPG IMG_0095.JPG IMG_0096.JPG
  21. Barn Find
    Barn Find
    from Missouri
    Dad's Auburn has an automatic ch***is lubrication system from the factory. It uses manifold vacuum to pump drips of oil that are distributed through tubes to spring shackles and the clutch throwout bearing, etc.
  22. And just think most new cars of today don't even have grease able ch***is parts. Most new cars are unserviceable. Most new car "technicians" Not mechanics don't even know what a grease jerk is. Amazing how technology works.
    FishFry, loudbang and Montana1 like this.
  23. Pete F
    Pete F
    Back in the late 50's early 60's my dad had a gas station in Port Chester where Marvel was located so we grew up with Marvel.
    The funny thing was in Port Chester Marvel was on one side of the street and Life Savers was on the other so on the day Marvel was brewing the oil and Life Savers was making wintergreen candy your nose could breathe clearly with the aroma.
    The oil worked great than and the engine flush called Hi Rev was another great product.
    My brother and I still use it and those oilers were great for flatheads that were prone to sticky valves.
    If they were adjusted properly there was no smoke at all.[​IMG]
  24. Elrod
    Elrod
    VIVA LA OILERS!!!
    Stogy, kadillackid and loudbang like this.
  25. Sheep Dip
    Sheep Dip
    from Central Ca
    Brought back memory's of my Grandfather 1894-1970, he swore by MMO in his cars, tractors and machinery.
    He also used Kerosene for everything, a cut or burn got a kerosene bath, and if he had a sore throat he gargled with Kerosene. Old time medicine I guess.
    48fordnut, rbrewer, Stogy and 2 others like this.
  26. Blues4U
    Blues4U
    from So Cal
    Gimmic, snake oil.
    Stogy likes this.
  27. Truck64
    Truck64
    from Ioway
    I dunno, you ever seen a squeeky snake?!
    SS327, rbrewer, Stogy and 1 other person like this.
  28. Nortryder
    Nortryder
    Wouldn't be the same as weak piston rings? Or worn valve guides?
  29. 56don
    56don
    Easter weekend.....must be resurrection time for old threads.
    Crazy Steve likes this.
  30. Oohhhh, that's cold.... LOL
