Hot Rods Marvel Mystery Oil, to use or not to use
Discussion in 'The Hokey Ass Message Board' started by Old2New, Jul 22, 2016.
  1. Gas and Oil
    69 vote(s)
    37.7%
  2. Gas only
    37 vote(s)
    20.2%
  3. Oil only
    11 vote(s)
    6.0%
  4. Do not use
    66 vote(s)
    36.1%
  1. Oh, you mean the mix ratio? 4 ounces per 10 gallons of fuel. I have used more Marvel than that with no ill effects on performance.
    pat59 likes this.
  2. tfeverfred
    tfeverfred
    It just plain works. Almost as good as Seafoam.
  3. What T-man said. It has caused problems in vintage/antique aircraft: A Marvel Mystery Oil sample tested for an NTSB post aircraft accident investigation published in 2003 found it to be composed of 74 percent mineral oil, 25 percent stoddard solvent, and 1 percent lard.[3]
  4. donno
    donno
    If it's good enough for a 5 cylinder Kennerer Radial, it's good enough for me/
    1927graham likes this.
  5. jimmy six
    jimmy six
    During engine ***embly I oil the cylinder walls with it. If I do a carbon ball on a refresh I wipe down the cylinder walls with it an white paper towels or tee shirt rags. I wipe until there only red on the white, may take 4-5 times.
    Speccie likes this.
  6. F-ONE
    F-ONE
    from Alabama
    I put some in a 6 cylinder and it turned into a V8.
    This stuff sure enough plain ole works!
    lbcd and LostBoy like this.
  7. If you use good oil and change the oil & filter regularly you shouldn't have to add anything to it. Now the fuel we have is often ****py. I add some diesel or 2 cycle oil to the corn gas in my older stuff that was made for leaded gas. I do the same with the diesel fuel in my old equiptment todays diesel is dry not as oily as what was available in the 40,s and 50,s
  8. Gerrys
    Gerrys
    Not MMO but some 2 cycle in the mowers if using ethanol tainted gas. Had problems with a valve guide on one head pulling out. Started adding oil and the problem stopped. I try now to only use non ethanol in the mowers. more expensive but not when you figure in the aggravation and money/time to repair. would use MMO if i didn't already have 2 cycle oil.
  9. Truck64
    Truck64
    from Ioway
    Yeah, It sure as hell "caused problems" because the dumb **** had installed about 4 or 5 gallons in the fuel tank. LOL
    Like I said, the old school recip guys used to purchase it by the drum. It's good stuff.
  10. I'll just add one piece of info about Marvel, and it has to do with farm tractors and butane many years ago.
    Back when IH had the Farmall M tractor as their most powerful tractor in their offerings, they also offered a butane fuel tractor. This was back when ethyl and the octanes were kings.
    Because of the cylinder heads not having hardened valve seats, the butane fuel source and lack of tetraethyl to lubricate them, as a gasoline engine would have, farmers installed Marvel Mystery Oilers to send a jetted mist of that lubricant into the intake vacuum to prevent the valves from pulling through th valve seats.
    I have some belief that this is the era that many folks came up with the ideal that MMO would be the solution to many other lubrication problems of that era.
    On older diesel engines using current ULSD, lubricity is a major factor for the parts that are intended to be lubed and cooled by the characteristics of older diesel formulas.
  11. Budget36
    Budget36
    I mix a bit with the fuel, but have run more through the carb directly, than through the tank...then again I don't live in the city limits;)
  12. JD Miller
    JD Miller
    MMO is good for cleaning handguns, rifles and shotguns too.:D
    Plus its good just cause it smells good and the chicks dig it too
    deathrowdave, tractorguy and Sharpone like this.
