mass saftey inspections rust?
Discussion in 'The Hokey Ass Message Board' started by 1950coronet600hp, Mar 23, 2012.
  1. ok got a new toy lined up, gonna have to get it inspected, how much rust will cause me to fail the safety inspection?
  2. Ralphies54
    Ralphies54
    Surface rust no problem, rust out big problem, same for frame rust. Find a small independent garage,their usually more interested in the $29.00 fee than they are in your safety and may overlook a lot. Good luck.
  3. S_Mazza
    S_Mazza
    A hole from the outside to the inside of the body should do it. Or any rust on the structural components that looks unsafe.
  4. Jalopy Joker
    Jalopy Joker
    just tell Inspector that it s not rust but, "Patina" which adds value.
  5. Slick Willy
    Slick Willy
    The old rule of thumb for this was a pencil sized hole and/or any visible rot. its amazing what a roll of duct tape and spray paint can hide in 20 minutes
  6. Yup...being able to see daylight through a body panle will get you to fail.
    Also, like Mr. Mazza said, any rot in structral components...frame, spring perches...stuff like that.
    That is, of course, ***uming the indpector is flexible enough to get a look under the car.
  7. 8FLEET9
    8FLEET9
    from MASS.
    the rule i use is jagged metal. if it can catch skin or clothing it fails at my shop. & tape of any kind is also a fail. it has to be a "permanent repair" fibergl***, sheet metal & pop rivets, or actually fixing it right are all ok. frame rot also fails but that's also a gray area cuz m*** doesn't put cars up on the lift, just jacks the front end to check for play. so if a vehicle isn't prone to frame rot it usually gets overlooked. go figure.
  8. Slick Willy
    Slick Willy
    Painted tape is permanent, isnt it??;)
  9. Slick Willy
    Slick Willy
    Yes, we all, as "M***holes" aim to kill, mame, or emotionally harm all men, women, and small children.:mad:
  10. rld14
    rld14
    Just a quick question.. if the car does in fact have rot in a safety critical area, why would ya drive it on the road anyhow? I can see a small hole at the bottom of a quarter panel being a tad nit picky tho.
  11. coupemerc
    coupemerc
    I just went through this with an O/T truck. The bed had a rust hole and that was enough to fail the inspection. They said that there was a risk of CO getting inside the truck. Huh?!
  12. the key points are good, i wouldn't drive it if the frame was rotted out lol, but just wanted to know what i am up against.. thats all..
  13. CruZer
    CruZer
    Willy, I must be another M***hole. I use metal tape (painted to cover dime holes in my rocker panels ) on my S10 daily driver. The inspector knows it and accepts it.
    I haven't done any maiming lately,though.
  14. LOWBLAZERO1
    LOWBLAZERO1
    whoa! strict laws in m***! i did not know that they were that bad. around here, they usually run the lights and honk the horn, and take your 12 bucks.
  15. familyman14
    familyman14
    12 bux?!?!?!?! try 29 up here in Taxachusetts.
  16. yup.. all to keep unsafe vehicles off the road lol i guess there trying to prevent this [​IMG]
    but i haven't heard about a snapped in half jeep toyota or dodge in a while so they must be doing their jobs lol
  17. Saxman
    Saxman
    LMAO! Don't forget about puppies and cute little bunnies. :D
  18. Nor me!
    I'm sensitive as ****.
  19. budd
    budd
    rust is not just about things falling off but also about exhaust fumes entering, and about acting like a cheese grater if you run someone down at a curb.
  20. scotsmerc64
    scotsmerc64
    I had a 70 OT Maverick with rust "holes" in the fender. Brought it to a big name shop and they failed it immediately. Drove up the road to a little mom n pop garage and they p***ed the car without even mentioning the holes in the fender or the lack of high beams. I guess it all depends on how badly they want $29!
  21. totally understand why they do it, i just wanna know what kinda work i am gonna have to do to get it driveable...
  22. Slick Willy
    Slick Willy
    As long as it doesnt look like Jaws attacked it, someplace will p*** it
  23. sgnova72
    sgnova72
    As other have said here, stick to the little one or two man inspection station. They are more likely to overlook certain things.
  24. S_Mazza
    S_Mazza
    I have never seen a car fail in PA for minor rust holes on a fender lip or something that doesn't affect the p***enger compartment or trunk. But holes that might let exhaust fumes into the seating areas, or holes that make the car prone to ... uh, falling apart ... those will make it fail.
  25. FivesDaddy
    FivesDaddy
    The whole sticker thing is a rip...just like the excise tax...
  26. Truckedup
    Truckedup
    I might be wrong,but I believe NY state has the most rusted out vehicles being driven daily.Completely **** faced PU trucks with flapping bedsides ,sagging cabs and you can see the drivers legs through the rot holes in the door.In fact it's so bad,the exhaust system isn't part of inspection other than the catalytic converter on vehicles newer than 25 years.80's GM ****box front drive cars seem to go on forever.I saw one yesterday billowing blue smoke and sparks ,dog legging badly,a rear axle control axle was broken away ,s****ping on the roadway.The driver was just motoring by like nothing was wrong.
  27. srs1
    srs1
    let me get this right. no matter what year your car is, even if it's 40-50 years old, it can't have any rust? is there no cut off date?
  28. Slick Willy
    Slick Willy
    srs1, you are correct, no cut off date, no rust
  29. jcapps
    jcapps
    from SoCal
    and I thought California was bad......
  30. Angry Frenchman
    Angry Frenchman
    hey Bill I used a bumber sticker once. but only once. lol
