does anyone know what years i can pull a rearend from that will fit under my 50 chevy without shortening anything? i know i have a 74 nova under it now and was told 67-69 camaro will fit also. any info would be greatly appreciated..also i need a master cylinder for my car, anyone know where i can pick up a new one? it has disc brakes up front and drums in the rear, but it leaks bad, and i dont know where i can get another that will fit..thanks everyone for taking time to read this..adam
I believe 71-80 Camaro rears will fit OK. For a new master cylinder, you could check Master Power Brakes or ECI. Or you could try posting this question on the main forum (instead of the Questions & Suggestions forum) where people more knowledgeable than me will see it.
no i cant fix it, the front part of the cylinder has 2 holes that the linkage for the clutch and the brake go through and there both reamed out bad, so my cluck is very sloppy as well, as for the leak i am not sure where it is exactly comming from...thanks guys
