Technical Master Cylinder Angle
Discussion in 'The Hokey Ass Message Board' started by ausbuick, Jul 16, 2014.
  1. ausbuick
    ausbuick
    G'day fellas,
    Just a quick question for you guys, I'm in the process of setting up a dual master cylinder on my 49 Buick, its a wilwood tandem item the same as this.[​IMG]
    I think I have settled on its final position, which is located above the old original stock item, but to clear all the gearbox and clutch linkages it had to be kicked up on a slight angle. So what I'm try to say is it ok to have the master cylinder on a slight angle?
    Cheers Darren
    Hotrodjohn71 likes this.
  2. Rusty O'Toole
    Rusty O'Toole
    It won't affect the working of the cylinder. Many cars have the master cylinder at an angle. It may make it more difficult to bleed out air, which is why we bench bleed them. If the angle is real sharp you may need a remote fluid reservoir but a slight angle is not a problem.
  3. ausbuick
    ausbuick
    Cool the front of the master cylinder is up by less than 1/2".
    Check out my 49 Buick sedanette build
  4. 1971BB427
    1971BB427
    from Oregon
    Some factory masters are a good inch difference from front to rear. As long as the fluid can stay covering the exit ports, it wont be an issue.
  5. unkledaddy
    unkledaddy
    Auto manufacturers took into consideration that you might be going up or down hill.
  6. Your limits are going to be set by the fluid level and amount of fluid it will hold.
    Obviously the more off level - the less fluid it can hold
  7. ausbuick
    ausbuick
    Thanks guys, I'll do a bit more fitting tonight.
    Cheers
