Technical Master cylinder bore 7/8 in,1 in,?
Discussion in 'The Hokey Ass Message Board' started by miller, Apr 22, 2024.
  1. miller
    miller
    from New Jersey
    Hi, I have a question. I have manual brakes front disc and drum rear. What is the correct master cylinder bore size to use if I do not change anything other than that? will the car have a soft pedal using 7/8 in. bore or will it be so hard I would have to stand on the pedal to stop? What happens if I use the 1 in bore? thanks for any info miller.
  2. squirrel
    Might depend on the rest of the braking system, and what car it's in, etc. We can only guess. Sometimes 1" is fine, sometimes 7/8" is fine, sometimes 1-1/4 is good, sometimes 3/4 is good.
    mad mikey likes this.
  3. miller
    miller
    from New Jersey
    So, it is not as easy as I was hoping.
  4. chicken
    chicken
    from Kansas
    Smaller bore = easier to push but pedal travel is longer. Larger bore= harder to push but shorter travel. Lots of things to consider ...pedal ratio, wheel cyl bore sizes, caliper bore sizes and fluid volume needs.
  5. Dan Hay
    Dan Hay
    I called Wilwood and asked the same questions, they asked me what Calipers I was using, and the pedal ratio, and what kind of car it was going in. When that was all answered they recommended a 15/16 bore. Turns out my stock master cylinder and pedal had bad geometry. It was 4:1 which is a good ratio for power brakes. I needed it to be in the neighborhood of 6:1 for manual brakes. I fixed that, so it should be good now. They car still has the motor out so I haven't tried it yet.
    chicken and mad mikey like this.
