Customs Master cylinder bore size
Discussion in 'The Hokey Ass Message Board' started by Lamar stoltz, Mar 26, 2025.
  1. Lamar stoltz
    Lamar stoltz
    Hey guys first time long time
    I’m wondering what master cylinder I should use for a current project. In the front I have a 98 3500 Chevy disc brakes. In the rear is a 89 international 4700 with disc brakes dual Piston calipers. Big guys
    Any suggestions on what size master cylinder I should be using? I currently have the original 3500 master cylinder and 3/16 inch brake lines and have a soft pedal. I know it’s been talked about a lot, but I thought I would post what I’m using
  2. Non-power, 1" or smaller. Power, 1.125 or larger. With a soft pedal, I would be looking for air in the system.
  3. big john d
    big john d
    from ma
    speedway motors has a section on determining master bore size by caliper or wheel cylinder bore it is on their website under a section called tool box
    Lamar stoltz and seb fontana like this.
  4. Jmountainjr
    Jmountainjr
    A disk / disk master would be preferred.
    bobss396 likes this.
  5. RMR&C
    RMR&C
    from NW Montana
    Is your Chevy master cyl for disc/disc or disc/drum? It makes a difference. My Chevy 1 ton has disc/drum and the M/C is 1 3/16" bore. Also it has 1/4" brake lines. I would use a master that matches your brake setup and vehicle weight
