1952-59 Ford master cylinder choice
Discussion in 'Off Topic Hot Rods & Customs' started by the gormandizers, Mar 11, 2014.
  1. the gormandizers
    the gormandizers
    from France
    Hello,
    I work to drop my 54 Ford, I chose a fatman kit for the front (disc and dropped spindels).
    The master cylinder don't work with disc brake.
    Can you tell me if it exist a perfect master cylinder to work with this kit and compatible with my brake pedal ?
    Thanks
  2. koolmercuryman
    koolmercuryman
    from iowa
    look in the FAQ sticky
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. the-stig
    the-stig
    I used one from CPP, $199. It can be used with disc/drum, has built in proportioning valve. Good looking too.
  5. the gormandizers
    the gormandizers
    from France
    Thanks guys !
    The CPP looks good ! Can I adapt it without modification on the arm ? Can I use the arm of the old master cylinder ? And do you use it with disc to ? It's not to hard to brake without booster ?
  6. the gormandizers
    the gormandizers
    from France
    JeffB2 : If the CPP is good without booster I prefer that because it looks better. Less bulky
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    You can try it and if you are not happy with it you can add the booster later,did you get an opinion from Fatman since you are using their stuff? Might be wise to do that first.
  8. the gormandizers
    the gormandizers
    from France
    Yes good idea, i try without booster and if i need it...
    I just started to install the Fatman kit. I hope to finish this week end.
    (I took it by contenair to save postage. but it take time to France).
    It looks good quality, the spindel are not foundry but welded but it's looks good.
    The only problem it's the disc-hub : the diameter of the hub is larger than the center hole in the wheel (original one). You have to machine the hub. And some little modifications on the lower arm (cutting little stuff). The spindle is a little inside: gain turning radius. Excuse my bad english :)))
  9. bashnaka
    bashnaka
    from england
    Or fit a remote booster like this on my 55 which is hidden down under the oil filter [​IMG]
  10. bashnaka
    bashnaka
    from england
    On this car the master cyl was moved into the car under the dash
    then the remote servo ( booster ) mount welded onto ch***is on the front left of the engine bay just under the oil filter
    servo mounted
    this keeps the booster out of the way giving you a clean engine bay and i know you probably dont want to use an internal pedal box but if you use the chrome master cyl and find that you need a booster you can use the remote type and move it out of the way ...hope that helps Duncan
  11. the gormandizers
    the gormandizers
    from France
    Thanks ! Yes it show more possibilty, thanks for all !
  12. the-stig
    the-stig
    I have the CPP master cylinder on my 56, no mods to the arm. It does work without a booster but I added one and it works better with it.
    When I put it in I had disc/drum, now I have disc/disc and it works with both.
    Without the booster it mounts to stock mounting holes, with the booster I had to make an adapter to mount it to the firewall.
  13. the gormandizers
    the gormandizers
    from France
    Thanks The-stig ! I mail the company to see if they send to France. Thanks youuuuu !
