1952-59 Ford master cylinder depth
Discussion in 'Off Topic Hot Rods & Customs' started by Steady Freddy, May 24, 2022.
  1. Steady Freddy
    Steady Freddy
    [​IMG] Re: 1957 Thunderbird Master Cyl. Push Rod
    I know this is an old thread but i,m changing master and it appears the total depth of the hole is quite a bit deeper , about 5/8 - 3/4 deeper .. I had a hard time getting the master off , it was grabbing so tight on that bushing that is no way coming out of the old master .. Can I just play with the length of a spacer till it seams good. Right now my pedal seems to go about 2-3 inches before I feel it contacting the piston thanks Fred
  2. jimmy six
    jimmy six
    When I changed to a Wilwood system they suggested an adjustable push rod for their Mustang set up. I bought it and set it to the stock length of my Ford to begin. It worked but I felt it was slightly shorter than needed to start the piston moving. I adjusted it out a few turns and set the lock nut. Been great ever since. I believe I bought it thru Summit with rest of the kit parts.
    JeffB2 and 53vicky like this.
  3. 53vicky
    53vicky
    I second what Jimmy Six says. The adjustable "mustang" push rod from Wilwood fits perfectly.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
  5. jimmy six
    jimmy six
    Same part Summit list for the same $20. Wilwood did not suggest theirs … just suggested one.
  6. 56longroof
    56longroof
    When I switched mine over to a dual chamber master cylinder I bought a adjustable push rod and set it to factory specs. There is a section that tells how much pedal travel is needed in the service manual if you have one.
