Master cylinder help needed
Discussion in 'The Hokey Ass Message Board' started by fatabone, Apr 12, 2007.
  1. fatabone
    fatabone
    I think this is a 62 Chevy truck m/c and would like to use it as a dual m/c instead of brake and clutch. Would I need to put a residual valve in the clutch side to make this work? Any help would be appreciated.
    Thanks Jr
      46.8 KB
      59.3 KB
      41.4 KB
      65.7 KB
      42 KB
  2. HemiRambler
    HemiRambler
    If your gonna set it up drum/drum then yes go ahead and stick a factory residual pressure valve in it (copy the brake side. If your disc/drum AND it's mounted beneath teh calipers then add in an aftermarket 2psi RPV plumbed into the clutch side and run that to the fronts.
    And Yes it's '62 Chevy truck (well a few years actually but '62 is one of them. Of course I always ask for parts for a '61 (I don't remember the cut off year but I know for certain it was used in '61.
  3. HemiRambler
    HemiRambler
    BTW those make a killer "balance bar" set up - for proportioning.
  4. fatabone
    fatabone
    Thanks. It will be firewall mounted and drum brakes all around.
