master cylinder mod?
Discussion in 'The Hokey Ass Message Board' started by scoop, Jan 29, 2014.
  1. scoop
    scoop
    I got a disc/drum master cyl on my shelf but it's for power brakes,I need manual can I drill the piston deeper for the push rod?
  2. KoolKat-57
    KoolKat-57
    from Dublin, OH
    That really doesn't sound like a good idea.
    The single most important thing on any car are the brakes.
    I would "bite the bullet" and get the proper master cylinder for the application that you are in need of.
    Better safe!
    KK
  3. fsae0607
    fsae0607
    Agreed, the brakes on your project are not the place to do R&D. Get the right MC :)
  4. V8 Bob
    V8 Bob
    Using a master cylinder with a deep counter bore on a custom manual system is good practice, especially if the push rod will not be retained in the bore, like most/all factory manual push rods. However, do not attempt to drill a shallow bore primary piston, because manual and power primary pistons are usually designed and configured differently. You may drill through and/or weaken the piston.
    JFYI, all of the Ford power brake masters I have, use or remember working with have the deeper push rod counter bore, normally around 1 1/4" or so. The manual masters I am familiar with have the push rod retained in a shallow counter bore.
  5. treb11
    treb11
    just use it as the trade in core for a proper manual master cylinder.
  6. 1971BB427
    1971BB427
    from Oregon
    Master cylinders are so inexpensive these days that it's not a place to scrimp, considering what the outcome might be.
  7. scoop
    scoop
    thanks,I'll go get the correct MC.
