I just finished mounting a under floor booster and master cylinder set up on my Econoline pickup. The master cylinder is a GM style unit and the reservoir closest to the booster is smaller then the reservoir that is the furthest from the booster. I am running a disc front and drum rear set up. Is the general rule that the biggest reservoir will go to the front brakes? Thanks. kgdb
Yes, w[FONT=Arial,Bold][FONT=Arial,Bold]hen plumbing master cylinders the rule of thumb is that the larger fluid reservoir volume will feed the front disc brakes.[/FONT][/FONT] [FONT=Arial,Bold][FONT=Arial,Bold][/FONT][/FONT] [FONT=Arial,Bold][FONT=Arial,Bold]There's a lot of good info here; Click here: Master Power Brakes - Welcome [/FONT][/FONT] [FONT=Arial,Bold][FONT=Arial,Bold][/FONT][/FONT] [FONT=Arial,Bold][FONT=Arial,Bold]Happy motoring. [/FONT][/FONT]
