master cylinder question
Discussion in 'The Hokey Ass Message Board' started by flathead 37, Jun 1, 2013.
  1. flathead 37
    flathead 37
    hey guys. i just got a 39 ford pedal ***embly to put into my 37 ford pickup beacuse im switching over to hydrolics. i was wondering if they make dual master cylinders that fit the three-bolt bolt-patern of the pedal ***embly. i have only been able to find single master cylinders for it.:confused:
  2. 40FordGuy
    40FordGuy
    I'm not sure about a 3 bolt dual unit,....But there are adapters to mate a "Corvette" style dual m/cyl to that pedal unit. be sure to get the one with a 2" deep pushrod "pocklet". I have one in my 40, and it clears everything with no issues.
    4TTRUK
  3. Old Tin and New Tin
    Old Tin and New Tin
    Will probably have to make or purchase a three bolt bracket to two boit master cylinder adapter. The adapters are available at Speedway, Yogi's, Parr, P&J, etc.
  4. 40FordGuy
    40FordGuy
    Ch***is Engineering also has one.
    4TTRUK
  5. Pgh_Stan
    Pgh_Stan
    Do you know which vette style master cylinder has that 2" pocket? Or which one does not?
  6. dave lewis
    dave lewis
    from Nampa ID
    Manual brake master cylinder has the deep pushrod pocket.
  7. Pgh_Stan
    Pgh_Stan
    What year vette masters?
  8. 5CHERO8
    5CHERO8
    Manual brakes are hard on the hands.
  9. V8 Bob
    V8 Bob
    Maybe on some, but not on many/most '60s-'80s Ford masters. Their power brake masters have the deeper push rod counter bores.
  10. 40FordGuy
    40FordGuy
    Ps; With that manual type Corvette style m/cyl, you'll need a longer pushrod, easy to make and fit as needed.
    4TTRUK
  11. J scow
    J scow
    from Seattle
  12. J scow
    J scow
    from Seattle
    Their proud of them!
  13. treb11
    treb11
