Hot Rods Master Cylinder ?
Discussion in 'The Hokey Ass Message Board' started by miller, Dec 18, 2015.
  1. miller
    miller
    from New Jersey
    ...Is there a master brake cylinder that looks good on the firewall of a 32 Ford....If so would you show a picture of it and where to purchase?....I did some searching and was not able to find the info I am asking about....Seems like what I do find goes on to say......'' DON'T PUT IT UNDER THE FLOOR, IT IS THIS THAT AND A LOT OF OTHER THINGS AND REASONS NOT TO PUT IT THERE ''.....Thanks for any info and help......Miller
  2. Atwater Mike
    Atwater Mike
    There's NOT a master cylinder that looks good on the firewall of a '32 Ford.
    I've welded enough ugly M/C holes shut in '32 firewalls to know that in spades.
    There is a number of mfrs of floor pedal setups you can use, but the best is using stock pedals ('32-'39, pref., and on to '48 p***enger car) Ford pickups also had floor pedals, so any from '32 to '52 would be natural.
    There would be some fabrication involved (simple bracketry) but I'd try to keep the pedals where they 'belong'...
  3. Deuced Up!
    Deuced Up!
  4. Nailhead Jason
    Nailhead Jason
    Absolutely. On a 32 you don't want to mess up that firewall with a master cylinder, especially an original firewall. To pretty to do that. Its like a zit on the nose of the prom queen. Everyone see's it and it looks ugly.
  5. V8 Bob
    V8 Bob
  6. miller
    miller
    from New Jersey
    ....Thanks for the replies,....so under the floor it will go......miller
  7. Jalopy Joker
    Jalopy Joker
    so, why are you interested in putting a M/C on firewall?
  8. scrap metal 48
    scrap metal 48
    I think a single reservoir like a early Mustang looks fine on any firewall.. A lot of guys don't like to use them but they were on most all cars until the mid-60's..
    Max Gearhead likes this.
  9. 56don
    56don
    Screen Shot 2015-12-16 at 9.00.42 PM.png Norwell's 32.I think they belong on the firewall. Its more practical.
    F&J and clem like this.
  10. miller
    miller
    from New Jersey
    ...only because I read that putting it under the floor was not a good place for it such as hard to bleed,easy to be damaged,etc.etc......miller
  11. don't believe everything you read, under the floor is fine.....there are 1000's of hot rods with them. all mine have the MC under the floor with no problems.
    there seams to be a lot of guys on here that have trouble getting brakes to work properly , why i can't fully understand...they are simple IF you know what you are doing.
    that `60 chevy pickup dual mater cylinder that 56don posted does look ok. one side for brakes , the other for clutch...so it really is just a single MC
    but....in choosing master cylinder you must pick one that will work with you brakes , not necessarily looks good. what are your brakes?
  12. miller
    miller
    from New Jersey
    ..at this time I don't have any brakes.....what I am thinking disc front drum rear...however that may change,....I don't have any brakes,lines, pedal etc in it now.....thanks for the info/help...miller
  13. The Ford car 52 and up style-
  14. hotrod harry
    hotrod harry
    from wisconsin
    Robert j palmer those are some large fuel lines going to carbs
    56don likes this.
  15. Here is the way I put mine under the floor. I have a stock K member. I used the stock pedals without modification. I started by bolting a steel plate to the rear of the K member. Symmetrical bolt patterns are nice but I used original bolt locations to avoid drilling new holes. Next I welded a piece of about 4 inch square structural tubing to the plate facing to the rear of the car. At the back I welded a vertical piece to mount the master cylinder. I shaped the rear to accommodate bearing blocks for the shaft that would hold the levers for rods that came from the original pedal ***embly and went to the push rod for the master cylinder. The length of the levers were sized to match the levers on a 1940 brake pedal ***embly. I made a cut out in the bottom to insert the ’39-’48 Ford master cylinder and a cut out in the top to check the fluid. I relocated the battery to a mirror image location on the K member. The master fluid level can be checked through the original battery cover in the floor.
  16. evintho
    evintho
    I second the '62 Chevy 1/2 ton M/C. Works well on my '27 roadster. '56 Ford truck drums up front and Maverick drums out back.
