Hot Rods Master Cylinder
Discussion in 'The Hokey Ass Message Board' started by warhorseracing, Jun 29, 2026.
  1. warhorseracing
    warhorseracing
    from cameron wv
    With the master cylinder shown upgrading from a single port to this double which would be the front brakes and which the rear? I have the required check valves and need to know which goes to where or does it matter. Master Cyl.jpg
  2. Bandit Billy
    Bandit Billy
    If you don't tell it which reservoir is going to which end of the car, it won't know.
  3. BJR
    BJR
    Usually the one closest to the booster goes to the front and the one in the front goes to the back.
    warhorseracing likes this.
  4. warhorseracing
    warhorseracing
    from cameron wv
    The back reservoir has a larger output fitting so that was my guess. Line is not bigger, 5/16th line but takes a larger fitting.
    RodStRace likes this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Pot belly master. Front port to front. Rear port to rear.
    Take note of front reservoir being wider.
    Toms Dogs likes this.
  6. BJR
    BJR
    The rear port goes to the front, because it puts pressure to the front brakes first then the rear, the way the internals of the master is designed,
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Toms Dogs and Okie Pete like this.
  8. 57 Fargo
    57 Fargo
    No it’s not. This is wrong
    patsurf likes this.
  9. RmK57
    RmK57
    The rearmost port goes to the front brakes. That master looks like a drum/drum unit. Usually the rear reservoir on a disc/drum cylinder will be larger because of the fluid capacity of the calipers.
  10. warhorseracing
    warhorseracing
    from cameron wv
    It is being used on a drum front drum rear vehicle. '65 F 100 upgrading from a single pot.
    Johnny Gee likes this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    More about GM because this is not a Ford master cylinder. IMG_6137.jpeg IMG_6138.jpeg
  12. Toms Dogs
    Toms Dogs
    from NJ
  13. tomcat11
    tomcat11
    ^Yep Johnny Gee is right GM is Front to Front. Plumbing my Model A as we speak using the early Ford manual drum drum dual pot. On the Ford 67-73 M/C the rear reservoir goes to the front. If you lose hydraulic pressure in the rear circuit the volume of fluid between the primary and secondary pistons is lost. the spring between them collapses, and the rear piston mechanically pushes the front piston maintaining pressure in the front circuit. If you lose hydraulic pressure in the front circuit the rear circuit will maintain pressure. Damn Fords!:D
    Edited for clarity.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    GM (design) pot belly master I plumbed on a 32 Ford. IMG_5270.jpeg IMG_5072.jpeg
  15. tomcat11
    tomcat11
    Looks good. I guess I will never understand why AN fittings are not DOT approved. Most everyone knows they are used extensively in race cars and aircraft.
  16. It's been answered already but, I look at the original application to see which line is front/rear.
