Projects MAXI TAXI 32 roadster
Discussion in 'The Hokey Ass Message Board' started by Frames, Nov 23, 2023.
  1. Frames
    Frames
    2023-11-23 20.40.48-13.jpg 2023-11-23 20.40.48-7.jpg 2023-11-23 20.40.48-1.jpg 2023-11-23 20.40.48-2.jpg 2023-11-23 20.40.48-3.jpg 2023-11-23 20.40.48-4.jpg 2023-11-23 20.40.48-5.jpg 2023-11-23 20.40.48-6.jpg I had a thread. Now I can't find it. Virtual building lessons for my 7 year old grandson. Now close to 10. I wiped off 2 1/2 years of dust today. Finished the templates for cutting out the floor. I had Eaton make a 36.5" X 2 " main leaf. More stability and a better ride. I will use about 4 more 37-40 leafs. I had the 32 Studebaker grille shell stripped of chrome. I will narrow it. About 1/2 " narrower than a 32. Then I will rechrome it and paint it but leave the surround chrome showing. I built a sprint car axle. That's enough typing for tonight. View attachment 5902618 View attachment 5902619 View attachment 5902620 View attachment 5902621 View attachment 5902622 View attachment 5902623 View attachment 5902624 2023-11-23 20.40.48-8.jpg 2023-11-23 20.40.48-9.jpg 2023-11-23 20.40.48-10.jpg 2023-11-23 20.40.48-11.jpg 2023-11-23 20.40.48-12.jpg View attachment 5902630 View attachment 5902618 View attachment 5902619 View attachment 5902620 View attachment 5902621 View attachment 5902622 View attachment 5902623 View attachment 5902624 2023-11-23 20.40.48-8.jpg 2023-11-23 20.40.48-9.jpg 2023-11-23 20.40.48-10.jpg 2023-11-23 20.40.48-11.jpg 2023-11-23 20.40.48-12.jpg View attachment 5902630
  2. elgringo71
    elgringo71
  3. swade41
    swade41
    from Buffalo,NY
  4. Frames
    Frames
    HemiDeuce, hook00pad and swade41 like this.
  5. Frames
    Frames
    12-6-23. De- arched the Ford leafs to go with the Eaton 36.5" X 2" main leaf. I like the Ford tapered leafs. 2023-12-06 22.01.09-2.jpg 2023-12-06 22.01.09-4.jpg 2023-12-06 22.01.09-5.jpg 2023-12-06 22.01.09-6.jpg
  6. Frames
    Frames
    bttt
    rod1 likes this.
  7. Frames
    Frames
  8. Kiwi 4d
    Kiwi 4d
    Down under we are not allowed to chrome suspension components due to hydrogen embrittlement. But some folks still do and no inspectors say anything.
  9. lostone
    lostone
    from kansas
    Love the caddy engine !!
    dana barlow and Jibs like this.
  10. Frames
    Frames
    Progress on the front axle. I won't be using a Panhard bar. KIS. I use a low arch when using the spring for lateral location. I sand and polish the parts before welding. Sure saves a lot of $ on the chroming budget. And does a better job. 2023-12-17 17.26.18-2.jpg 2023-12-17 17.26.18-3.jpg 2023-12-17 17.26.18-4.jpg For the heavy engine 6 degree caster. Level spring front to back.
  11. Frames
    Frames
  12. Dave G in Gansevoort
    from Upstate NY
    Nice! Love the simplicity. Might have to rethink the Whatever project front...
  13. Frames
    Frames
    The frame design dictates the shocks be mounted behind the axle but I like it better that way anyway. Much cleaner view of the front axle. 6.1 degrees caster. I mounted the hairpins inboard over that of a Ford axle to allow for more turning angle before the tires rub the hairpins. In stock 3.5" dropped steering arms. I will be changing to 1.75" dropped arms. 2023-12-23 14.15.17-1.jpg 2023-12-23 14.15.17-2.jpg 2023-12-23 14.15.17-3.jpg 2023-12-23 14.15.17-4.jpg
  14. Frames
    Frames
    Speedway Motors 1.75" drop steering arms worked out great. I never use a store bought Vega mount. Took many hours to get the box mounted just right. 2 bolt bracket welds to the bottom side of the frame. Now I can gusset the engine mounts with clearance for the U-joint. Will only need a U-joint at the box and at the steering column. Notice how I narrowed the frame rails at the front for radiator clearance. 2023-12-31 10.12.32-1.jpg 2023-12-31 10.12.32-2.jpg 2023-12-31 10.12.32-3.jpg 2023-12-31 10.12.32-4.jpg 2023-12-31 10.12.32-5.jpg
    winr, dana barlow, Just Gary and 6 others like this.
  15. hotdamn
    hotdamn
    Lookin good Dennis!!
  16. Frames
    Frames
    Almost a roller. 6 pin sprint car hubs for F 150 spindles. Shrink sleeve fit for inner bearing. Stock Ford car outer bearing. Cut back spindle for shorter hub. I found a seal that fits the hub and spindle. Stock Car Products 5 x 5 hat and rotor. Drilled for 3 pins and bored to fit hub. Turned used rotor. Voila, like new. Years of beating on the spinners makes them a little flatter. Work good on the front with narrower wheels. 2024-01-06 21.39.58.jpg
  17. Frames
    Frames
    Nance magnesium 6 pin wheels. 6 kidney bean holes with a gusset in between holes. Beat flat spinner. I will make a polished center cap. 2024-01-09 16.56.08-1.jpg 2024-01-09 16.56.08-2.jpg
    winr, dana barlow, GordonC and 5 others like this.
  18. Frames
    Frames
    I cut off the upper part of the water pump eliminating the thermostat. Two Aeroquip hoses direct to the radiator. Cools real good on my other hot rods. 2024-01-09 16.56.08-3.jpg 2024-01-09 16.56.08-4.jpg 2024-01-09 16.56.08-5.jpg
    winr likes this.
  19. Frames
    Frames
    img609.jpg Hope to use these 51 Olds 98 tail lights but move them up about 3" from where I mounted the 37 Ford tail lights on my 32 I built about 15 years ago. That is a Gibbon body. The Rats Gl*** body is LOADED with wood back there. I hope I can pull it off. 2004-01-01 00.01.54.jpg
  20. Joemama
    Joemama
    Following along, looks good!
  21. Frames
    Frames
    DF1FD90B-74D3-4B89-9E86-D6E34DD4FE7D(1).jpeg Narrowed the 32 Studebaker grille shell 1.250 " at the top and about 2.5" at the bottom. Now the sides are parallel and now it is a little narrower than a 32 Ford grille shell. To the Evaporust tank tomorrow. Then welding.
  22. Frames
    Frames
    With 2" grille shell ground clearance on my black 32 I was able to get a 3/4" lower shell than stock. 32's look humped up in front to me. Custom built radiator. The Studebaker shell is shorter so with 2" G C I will be able to get the shell another 1" lower at the top. Much better flow with the top of the cowl. 001.JPG
    oliver westlund, Just Gary and NJ Don like this.
  23. AmishMike
    AmishMike
    I see you only running a shackle on p***enger side front spring. I know some dirt racers used to do this & eliminates need for panhard bar. Do not remember handling reason for doing this. Nice build
    Unkl Ian likes this.
  24. Frames
    Frames
  25. Unkl Ian
    Unkl Ian
    Was this called a "Dead Perch" ?
  26. DDDenny
    Yes.
    Here is another style on my roadster. 20181124_125328.jpg 20181016_115416.jpg
  27. Frames
    Frames
    Look close. My P U dead perch. My 32 dead perch [ welded up schakles ] and the obvious sprint car dead perch. 2004-01-01 00.00.00-4.jpg 2004-01-01 00.00.00-5.jpg 2004-01-01 00.00.00-6.jpg
  28. Frames
    Frames
    Spent an entire day fabricating headlight/shock mount combo. Headlights too high. 2004-01-01 00.00.00.jpg 2024-02-22 08.34.24.jpg Made a new lower mount for shock absorber. Spent another day making this mount. Top of headlight 21" off the floor. Lower than that only makes the grille shell look higher. I don't like the bug eye look. Headlights sticking out in front of the grille shell. Sold the Electroline and the E & J. [ I got to be different ] Will make my bullet headlights about 9" long by sectioning these biggies and using 1/2 " front of 7" diameter Dietz. I built 1 set like that for a BFF and a set of 5.750 " diameter for my Willys. I may use the smaller rare 820D park lamps not the more common larger ones. Not done with shock mount. Needs additional support of the shock itself.
  29. Frames
    Frames
