Projects Maximum Evil is born.
Discussion in 'The Hokey Ass Message Board' started by HotRodChassis, Aug 2, 2008.
  1. magnet
    magnet
    I hate Camero's ...
  2. continentaljohn
    continentaljohn
    I second that:D
    So when are you going to build that skinny tire:D
  3. Django
    Django
    from Chicago
    Probably when I find another Weiand Banger intake like the one I lost last week on ebay. :eek:
  4. SinisterCustom
    SinisterCustom
    You've never street raced before.....have you?
    "Wanna run?"
    "Sure, whatcha got?"
    "Oh, just a stock Camaro with an high flow intake...that's all"
    "OK....say for $50?"
    "How 'bout $200?"
    "Uhmmmm.....can I look over your car?"
    "No."
  5. blackout
    blackout
  6. billbrown
    billbrown
    looks like we may have ourselves an automobile race.
  7. FWIW the LS1 only came in the Camaro from 1998 - 2002, a 1997 Camaro Z/28 would have an iron block LT1.
  8. HotRodChassis
    HotRodChassis
    Alliance Vendor
    And you've never met Joe-Bob. It's stock. It wouldn't matter if it wasn't. No 3800lb car is going to take something out of this shop. Big talk, or science? Joe-Bob will be the judge.
  9. Morrisman
    Morrisman
    from England
    I love it. :D
  10. My '00 Camaro was lightened to 3100 w/o driver with a 9" and 6 pt rollcage and a T400. Stock is ~3400 - 3475.
  11. SinisterCustom
    SinisterCustom
    Joe-Bob sounds like a big guy.....hahaha....
    Go get 'em Kevin!
  12. Cross Rodder
    Cross Rodder
    Looking sweeeeeeeeet!
    I love chopped T's but Im to darn tall.
  13. swade41
    swade41
    from Buffalo,NY
    sounds like as good a reason as any to build a bad *** machine.....lol
    I know my own T at 1800 lbs will boil the hides if you put your foot to much into it at the launch, better learn how to roll it out.
  14. ThatOne49
    ThatOne49
    good luck guys, i'm rootin for ya.
    I got alot of **** talk from guys in Civics, Camaros, Mustangs, a few corvettes, etc. on me and the pops '35 Ford. Rarely did they ever have anything under the hood and rarely do they ever wanna race after they find out what we got (they usually spew all the details about their car before you say anything about your own). I've come across few people who can "talk the talk, and even less who can walk the walk" (for lack of better words)
  15. Appleseed
    Appleseed
    That needs to be on HRCC's shop wall.
  16. Mr48chev
    Stock up on beer and popcorn this sounds like it is going to be fun. Had to suscribe to the thread so I don't loose it.
  17. HotRodChassis
    HotRodChassis
    Alliance Vendor
    And what kind of power are these 3800 lb. cars running? 1200-1500 hp? The Black Car (TM) weighs 3080 lbs. and makes 930 hp, runs 8.48 at 153.05. At a tenth per 100 lbs, well, you can all do the math.
    The point here is not to start a weight-speed ******* match. So far, we've been able to not "boil the hides" on some other cars. Transfer of weight, proper suspension geometry, spring rate, etc. is all key to hook. The point is to hand a newer car owning **** talker his ***-holieoh.
  18. Django
    Django
    from Chicago
    The Black Car is wicked fast, no doubt. I don't think I have any pics of it.
  19. Awesome!! You guys are having way to much fun...;)
    Joel
  20. Lucky77
    Lucky77
    Any chance Maximum Evil will make an appearance at the Pileup? Like over in the project section? Sure looks tuff!
  21. NortonG
    NortonG
    This is gonna be epic!
    Norton
  22. HotRodChassis
    HotRodChassis
    Alliance Vendor
    Thanks Lucky. Yep, we're hoping to have it a roller for the HCPU. Maybe even the funny car cage installed.
  23. jw_deuce
    jw_deuce
    from Central OH
    HotRodch***is- The cars looking great, I just chopped my 27 last night. My first chop. Do you have any more pictures of the chop? like how the pillars fit together and everything, The top part of the roof is about a half inch wider than the bottom once I sat it back on the body. How do you correct this, do I have to section the roof part or just use a porta power and just push them out to match back up?
    Thanks for any help!
    Justin
  24. HotRodChassis
    HotRodChassis
    Alliance Vendor
    A square top chop isn't that hard, but there are a ton of different ways of doing it. Some chop the front pillar in the middle and the slice and spread the top and bottom sections and then weld them up. Some cut the rivets that hold the upper sill (piece over the door) to the front pillar and then just cut the front pillar down. I'm sure there are several people on the board that would post several different ways of chopping your car. I could suggest starting another thread with photographs of what you've already done and ask for advice. It's hard for me to give you advice without knowing how much you've chopped out, where you chopped each section, and what it looks like now. Hope this helps.
  25. Haywood
    Haywood
    from M'boro,TN
    HELL YEAH!!!
  26. HotRodChassis
    HotRodChassis
    Alliance Vendor
    We've got the front end on, and it's on it's own front wheels. We also located a pair of NOS Avon 3.50-18 H rated Speed Masters for the hoops.
    The rear slicks came in also, and now with the front end in, we're ready to go on the building the Double Live Gonzo rear axle so it'll plant the skins.
  27. 1LOWCHIEF
    1LOWCHIEF
    Anything noteworthy to update us with?
  28. LoBrow
    LoBrow
    from MI
    Can you show some close up shots of that front engine plate/mount?? And also some pics of this "black car".... Thanks
  29. HotRodChassis
    HotRodChassis
    Alliance Vendor
    Yep. I've got the rear end fabricated and have been installing the rear suspension. The seats are mounted. And if Moser comes through and the axle shafts come in tomorrows UPS, it'll be on it's own wheels, and at the Pile Up in our booth! I'm going to try to get some of the cage in before the show, we'll see. I'll post some photographs later tonight.
  30. HotRodChassis
    HotRodChassis
    Alliance Vendor
    Ok, here are some photographs of what's been done.
    Rear axle in progress:
    Some welding:
    Seats mounted:
    Started the cage. This is what I got done last night:
    Here's a shot of the rear suspension:
