I tried the search feature and came up empty on this one. Planning on a g***er direction for my car, (actually technically "modified production" since I don't plan on a straight axle) and need to know what's the max. I can go on rear tire width. Backspacing on the wheels would be a bonus. Car's a 56. Thanks!
I'm running 235/60/15's on the back of my 56. The wheels are Cragar 15x8 with 2½ inch backspacing. I am running a 98 Blazer rear end which is 4 inches narrower than the stock rear. I had to use lowering blocks to get the caliper to clear the leaf spring.
225/70R15s on stock 6" steel rims from a '65 Galaxy on my '56 Fairlane. I didn't check the wheel backspace. Stock rear end, Hi-Jacker air shocks. A tight squeeze but got them on and with good clearance all around.
When I first built my 56 around 1970, I made a mold of the front wheel well openings and made a fibergl*** edge (flare) that looked like the front fenders opening. I pop riveted them on, and opened the body. It allowed me to run 10x15 Cragars with L60x15's. When i redid the car and scored some cheap rear quarters I opened up the inside of the wheel well and welded the outer edge to a piece of 1/2" bar and rolled the edge. I made some custom offset wheels to maximize the space available. I used some Cragar centers and rims from 15x8 chrome reversed. I put the centers in the ice box and the rims in the oven when my wife wasn't around. The centers fit in and I used a dial indicator and hammer to get it near 1/8" runout, then welded them. I'd half to measure the backspacing. The rear axle is 57 Ford 9" and it bolted right in. Right now there are 30" Hoosier's tucked under, but it's real close. A set of Torque Thrust 17x8's with 285 x 40's also just clear. http://rides.webshots.com/photo/2548700940058831858tBylEL
Wow, that really stuffs those wells on your '56! Looks great. Hey is that a '62 Catalina in background? I always liked those old widetrack Pontiacs too.
I looked last night and the Hoosiers are 30/9R x 15's but the footprint is actually 10" wide. The American wide track Pontiacs were neat looking cars. This Pontiac is actually a Canadian built car. It was built on a Chev ch***is and had a 283 and looked kind of spindly the way I bought it. In Canada there were Strato Chiefs, Laurentians and this is a top of the line Parisienne 4 door hardtop. I think the US Bonneville was longer wheelbase, while Catalinas were the same length. The motor and trans is a Fuel Injection '95 Impala SS LT1 350/4L60E. The engine bolted in with 283 mounts, but splicing in the computor was a learning experience. It gets about the same fuel economy as our Silhouette van and being 400 lbs lighter than an Imapala SS should be capable of running 14's. It's my son's car now, but it lives in my garage so I get to drive it to work on a regular basis. My son lives in an apartment so he's talking about selling it. http://rides.webshots.com/photo/2184550240058831858RaWKrO http://rides.webshots.com/photo/1292065189058831858wmAEdY
The first car I ever owned was a 62 Catalina ! I had a 389 with a 3x2 on top that the guy I bought it from installed . It was a heavy car but once you got it moving , it would just keep pulling till I let off the gas . I traded a stack of about 35 rock & roll LP's , a hopped up mini bike and a set of chrome reverse rims for the car ! I really did like that car . I could get a lot of friends in that car real easily due to how roomy they were . Was great for cruising and no one knew what you had under the hood either ! After I sold that car , I bought a 66 Chevelle and then the list goes on & on for all the cars I owned in my teen years . That Pontiac Catalina was one of my favorite cars that I owned . I could also get about 6 or 7 friends plus beer in that trunk for night at the drive-in ! Those were the good ole days ! Jim
