Technical ***May 2017 Banger Meet - Sun shining on all 4***
Discussion in 'Traditional Hot Rods' started by Jiminy, Apr 30, 2017.
Tags:
  1. Jiminy
    Jiminy
    Here is the banger link list:
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
  2. Bluto
    Bluto
    Plenty of 4's here but very little Sun yet.
  3. plenty of sun here still.
    wrapping one up to take to el mirage in a couple weeks.
    J
  4. denis4x4
    denis4x4
    from Colorado
  5. winduptoy
    winduptoy
    Checking in
    10" of snow = 15" of mud. Late spring storm and I am getting anxious for a banger outing.
    Thrust bearings now in a really good B block that has been fitted with inserts. It has a standard/standard counterbalanced crank. We will see where this winds up.
  6. hotrodA
    hotrodA
    There was a very small Model A hill climb this past Friday over in the small town of Unicoi, TN. My friend brought over his B powered roadster, but unfortunately had electrical problems.
    Very light turnout, but some nice cars plus notables such as Ron Kelley from Texas and George Miller from North Carolina.
    Curt's roadster
    Miller's speedster with hand made aluminum OHV
    Ron Kelley's speedster hauler. Four door, tilt bed, B Cragar (?!) with 5 spd and AC!! Sorry for the bad pic!
    Unusual Lingo head (looks like a Cragar). Aluminum cross flow with Winfield.
    Pufff, cactus1, Old Dawg and 5 others like this.
  7. Bluto
    Bluto
    It's been a long ugly Winter ....... Wet Grey and Cold. Spring isn't and Summer is not a "Summer Forecast"
    Racing will start in a couple weeks with test days only. We'll back out with the little Fiat 126p.
    It's nice to see pictures of sun and cars gathered together ... people having fun.
    With my vision failing and hand tremors I feel OK taking things apart but not ***embling engines. So I'm designing and having items made and projects stack up for a time when I can do something more productive. AND hoping this is just a bump in the road. In a few months there will be one more series of eye surgery and maybe it will help. The old guys here will tell you. Just about everything takes a year to heal-up The years stack up. So do the projects. Sad but true.
    Here's something to think about :)
    Given the right lever we could all move the world
  8. waxhead
    waxhead
    from West Oz
    Thanks for the hill climb pics. Checking in for the month
  9. Happily hoarding parts on this fine Mayday. Worked on my rendering, far from artistic. Mulled over using more T style suspension bits on this one, but changed my mind, going to use more Model A tie rods (and ends) grafted into various parts. That extra metal just makes me feel a bit more secure.
  10. Bluto
    Bluto
    Doug
    Remember I still have this you can use till you find something good DSC06776.JPG DSC06775.JPG
    Sorry about my shaking hands!
    Old Dawg likes this.
  11. :)
  12. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    Could you possibly give me the TT ch***is length ?
    Tricky dimension to track down on tinternet
  13. 126" LOA and 123" CC
  14. studebakerjoe
    studebakerjoe
    TTFrame-6-26.jpg TTFrame-8-20.jpg TTFrame-7-19.jpg Andrew hope this helps.
  15. Bluto
    Bluto
    Man!!! Wish I had a set of plans like that for the junk I've worked on all my life. You Ford guys are really lucky. Provda!
    Outback and Old Dawg like this.
  16. Look at all that room for a speedster that will fit a normal human! Plus lots of storage space.
  17. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    Thanks fellas. Big help
  18. Crazydaddyo
    Crazydaddyo
  19. Bluto
    Bluto
  20. OOOHHHHH MMMYYYYYY!!!!!!!!!!
    If you need help with that let me know.
    BTW, Wonder bread plant in Burbank is a missing a mixer like that.........
    J
  21. Andrew Mccann
    Andrew Mccann
    from Bristol UK
    Oh yes.
    Engine trumps. My favourite game
  22. Bluto
    Bluto
    Like John says...
    It Does look heavy Dan......:eek:
    I do have one of those oil pumps somewhere round here.
    Crazydaddyo likes this.
  23. Crazydaddyo
    Crazydaddyo
  24. Crazydaddyo
    Crazydaddyo
    This one is the only one of these that I've posted that I own.
    Old Dawg, chriseakin and Dannerr like this.
  25. This will work also.
    Did you notice all the plates welded to the outside of the previous pictures block?
    I have heard about people just welding plates allover the outside of the block to strengthen them up.
    John
  26. Crazydaddyo
    Crazydaddyo
    I think that one is a HAL block or early prototype.
    The plates on the block were the water jacket covers.
  27. The37Kid
    The37Kid
    Single stick ROOF I sold to Doc Pruden back in 1973 or so. Is it still some were in California? Bob DSCF7999.JPG
    Old Dawg, chriseakin, Dannerr and 2 others like this.
  28. BlockBuster
    BlockBuster
    from SEMass
    Guys...looking for the Dennis Cling hydraulic brake conversion bracket and m/c for Model A transmission. Mr Cling said the market fell out and he's not producing them anymore. Of course I found this out after I finally pulled the trigger and ordered it last week. Does anyone have one, know someone that has one and doesn't plan to use it? This is pretty much the last mechanical operation before I get my coupe on the road. I have a WTB on the Ford Barn, but couldn't post one here on the H.A.M.B. Any and all help appreciated.
  29. 97
    97
  30. Juggler
    Juggler
    You could try Sammy at Arizona Model A. He stocks Dennis' stuff and might still have something on the shelf. Longer shot might be Derek Thomason in NZ who also took a lot of Mr Cling's stuff home.
