Technical ***May 2022 Banger Meet Thread - May Your Banger Run***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 1, 2022.
  1. Yes, two completely different motors. the 2up 2dn was a std port flathead.
    I have been lucky to work on some pretty impressive motors, J
    Jet96, Dustyp489 and Outback like this.
  2. After a few margaritas, I decided to test out a new app on my iPhone with my Wells setup.
    It's rough, but pretty wicked what technology can do! This is from about 60 photos all meshed together.
    T-Head, Jet96, Dustyp489 and 2 others like this.
  3. Kevin Pharis
    Kevin Pharis
    from Califunny
    What a fantastic project! Did it run a Winfield high rise manifold? Did it shake like hell...?
  4. My surname too. I’ll dig out the T*****croft front drive setup when I have some time.
    Jet96 and Outback like this.
  5. no, it ran two 2" throttle bodies and Hilborn FI
    It didn't shake as much as it thumped, about 135 hp on gas
  6. Outback
    Outback
    from NE Vic
    I would love a 2up 2dn crank!
    Jet96 likes this.
  7. Steves46
    Steves46
    from Florida
    I had to replace the water inlet housing on the left side of the engine and was planning on using a cork gasket. Should that be ok or am I better off with paper?
  8. The crank is only half the fun
    The cam is fun to build
    J
  9. That would be awesome! You can send photos on Instagram, @bangersmodified
    Outback likes this.
  10. V4F
    V4F
    from middle ca.
    on t
    on the water pump i use paper but with a coating of sealer
  11. Outback
    Outback
    from NE Vic
    I ***ume that you machined the crank from billet 4130?
    Firing order 1324?
  12. jim1932
    jim1932
    Well got my Gaskets from Renner's and I must admit, I change the cork top whan it drys out, but the washer size ones I rarely do. Changed them all. Also noted a fair amount of misc. settiment in the main part of the pump. Cleaaed it, blew it all out and put all new gaskets in. Will run it after work and report back.
  13. Steves46
    Steves46
    from Florida
    All good-no leaks!
    Outback likes this.
  14. Crazydaddyo
    Crazydaddyo
    Got the coupe ready in time for the Antique Nationals at Irwindale Drag strip this Sunday.
    Brought home some hardware too.
    G Baese, Jet96, Dustyp489 and 6 others like this.
  15. Dustyp489
    Dustyp489
    What were your times, speed
    I take it is 1/8 th mile. Great job
    Crazydaddyo likes this.
  16. T-Head
    T-Head
    from Paradise.
    John, your are certainly right about that. Made patterns, had it cast, and machined this 300 CI, 16-valve four-cylinder block with blind cylinders.
    The original block and two sets of rocker arms.
  17. drtrcrV-8
    drtrcrV-8
    HOLY F....N WOW!!! Details PLEASE!!
    Outback likes this.
  18. Crazydaddyo
    Crazydaddyo
    Outback and Jet96 like this.
  19. Jet96
    Jet96
    from WY
    @T-Head
    -that thing is cooler than a penguin's undies...
    I would like to hear it!
  20. You made the fastest run getting on the freeway to go home!!
    Congrats, J
    Outback and Crazydaddyo like this.
  21. I'm a bit more excited than I should be. The front cover is in the mail, and should be arriving soon. As you guys can see, it looks like it accepts the tang off of a distributor shaft.
    I thought up an idea, essentially tapping the face of the cam, and running a bolt with the tang on the end. This would most likely be 3D printed, casted, then machined.
    At this point, I'm not sure if it'll put stress on the cam but it's worth a test!
  22. T-Head
    T-Head
    from Paradise.
    Its a 1915 Duesenberg racing car that finished second at the 1916 Indy 500. It has a 3-3/4" x 6-1/2" bore and stroke, only two main bearing, which are ball bearings, tubular rods, and a dry sump oiling system. It has three ge****ts will do 125 mph on the middle set. Its the most original pre-WW1 US built racing car and the only thing changed on it are the block and the removable tail section. It was raced until the late 1920s and parked until 1941 when a collector bought it and put it back on the track at Thompson, CT. It's complete history is known.
    GuyW, Hemi Joel, barrnone50 and 8 others like this.
  23. Crazydaddyo
    Crazydaddyo
    Found some footage from Sundays race.
    barrnone50, BeaverMatt, Jet96 and 2 others like this.
  24. That is quite the project, very nice.
    Good on you, John
    Outback and Jiminy like this.
  25. Jet96
    Jet96
    from WY
    42FDF09F-2822-4F73-AF43-7A858199996E.jpeg Wish this were a little clearer, pretty cool stuff going on there...
    BeaverMatt and guitarguy like this.
  26. Kevin Pharis
    Kevin Pharis
    from Califunny
    Wicked cool! Half a Hisso...?
  27. hotrodA
    hotrodA
    I was going through my banger parts shelves and ran across these Gemsa bronze caps and thrust insert. I bought these from Joe 25+years ago, when he was still alive.
    What's their history and development?
    Any benefit to running them?
    What's involved?
    What about clearances?
    Or are they just paperweights and Gemsa collectibles?
    Thanks!
    Bill
    Jet96 likes this.
  28. T-Head
    T-Head
    from Paradise.
    This Ford Race was held at the Legion Ascot Park Race Track in the late 1920s and the clever owner of the #7 car "channeled" and lowered the front half of the body over the frame. In addition, the radiator was "sectioned," and the hood was lowered, giving the car a smaller frontal area for better aerodynamics.
    G Baese, hotrodfil, Jet96 and 3 others like this.
  29. raaf
    raaf
    @T-Head - I've always liked this look, thanks for sharing the photo. As you said it probably involved a combination of sectioning, channeling and lowering.
    Does anyone know if there is a general description for this overall style - where the top of the fenders end up essentially parallel (or close) to the top of the body lines? It's a style that I see with a lot of early European cars. Example: (Atalanta)
    I ask because I would like to research or find more Model A's (or T's) customized in this way.
    Jeff34 and Jiminy like this.
  30. Fabber McGee
    Fabber McGee
    Hey guys, several years ago I saw an article about a young guy in the 50's that couldn't afford a car faster than his Model A, but he was working in a machine shop (I think) so he put a small block chevy head on it. I saved the article in my computer, but can't find it now except the little thumbprint photos. I searched Google and HAMB and can't come up with it again. It must have been on the HAMB when I saw it , but I can't find it.
    Can someone come up with it for me? Thanks.
