Technical ***May 2023 May Showers Bring Bangers***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 1, 2023.
  1. Jiminy
    Jiminy
    Link to previous month: April 2023 Banger Meet Thread
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    stubbsrodandcustom and Outback like this.
  2. Outback
    Outback
    from NE Vic, Oz
    I'm here but with nothing to add, mine is still patiently waiting it's turn again. IMG_20230501_205859527.jpg
    metalhead140, Jet96 and Old Dawg like this.
  3. 62pan
    62pan
    Fired up the roadster for the first time this year. Found out that the top gasket on the B fuel pump had dried out over the winter leaving quite a mess on the floor when I turned the fuel on. First time that ever happened.
  4. denis4x4
    denis4x4
    from Colorado
  5. wuga
    wuga
    43 degrees here in Southern Ontario today. Still a little cool for the RPU. Biting at the bit.
    Warren
  6. Had to rebuild a 94 for one of the coops
    It took 2 to get good part’s enough for a decent one
    All good now
    J
  7. V4F
    V4F
    from middle ca.
    good morning
    are we ever going to find "Normal"
  8. wuga
    wuga
    I have installed a set of bomber seats using the Hells Gate side rails. I really like the look, but I find getting in and out of the restrictive door of the RPU is had on this 80 year old **** dragging over the raised sides. I want the aluminum seat, but I don't want to increase the bottom cushion. Is anyone using an aluminum bomber seat with padding that has lower side rails?
    Warren
    stubbsrodandcustom and Old Dawg like this.
  9. Hitchhiker
    Hitchhiker
    It's alive!! More details incoming...
  10. Crazydaddyo
    Crazydaddyo
    Had two of mine at the OC Model A Pancake Breakfast yesterday
  11. trikejunkie
    trikejunkie
    from Scotland
    I`m still here hacking on with my coupe, rear brakes and axle all completed as is the fuel and exhaust systems-I just made a pulley to fit the v8 water pump that will take a 32 fan .Tomorrow it is front brake lines and new front lever arm shocks to fit .I`m getting there !
    4BangerDean likes this.
  12. IMG_1538.jpg It's been a while since I've checked in. Recently got my coupe up and running after a several year slumber.
    winduptoy, cactus1, Jeff34 and 9 others like this.
  13. MJW
    MJW
    from NJ
    Picked this up at a Model A only swap. Ruckstell Aluminum head for a Model A. Its really cool but I would be afraid to run and ruin it and don't need any more wall hangers.
    Only info I found was a photo of one on a motor at the speedway museum site.
    Looks like it was run and then flycut, there is some pitting in the combustion chamber but no cracks or repairs. I'm going to sell it but wanted to offer it up here first PM me if interested. I'll probably put it in the cl***ifieds this weekend if no one here claims it..
    callcoy, Old Dawg, BeaverMatt and 4 others like this.
  14. IMG_1391.jpg I forgot to load a picture of the car!! DOH!!!
    mvee33, Old Dawg, Crazydaddyo and 2 others like this.
  15. Hitchhiker
    Hitchhiker
    All right! So....faulty torque wrench resulted in a leaking head gasket. Gasket replaced. Good torque wrench used. Seems to be holding. Pretty amazing the power difference and driveability difference between my engine and a stocker! I'm pretty pumped. I'll report back once I break in the engine a bit more and give it all she's got!
  16. V4F
    V4F
    from middle ca.
  17. Thanks
  18. No compe***or's were willing to come out and play at the upcoming vintage races the middle of this month at ****onwillow Raceway Park. So regrettably we had to "pull the plug" on the "PreWar/Historic" race group!
  19. Stovebolt
    Stovebolt
    No wonder the B leaked oil from what was left of the front seal.
    Popped a rod and main cap off - no babbits - YAY!!!
    metalhead140, Jet96, Outback and 4 others like this.
  20. V4F
    V4F
    from middle ca.
    where did you get the "honey combed" radiator ? very nice
  21. trikejunkie
    trikejunkie
    from Scotland
    I have not put a picture up of progress for a while so here is one! New pulley made for the V8 water pump and fitted too,I made it 0.002" interference as it is aluminium and added a grub screw-takes a 32 fan to keep the look. 20230503_164344.jpg
  22. Outback
    Outback
    from NE Vic, Oz
    By accident really, when I was looking for a good rad a localish dealer had this one at a great price, wasn't till later it dawned on me it was different to normal
    It still has the makers badge on it too.
  23. Hitchhiker
    Hitchhiker
    Did a little driving today. Farthest I've taken it....
    It's really interesting driving this thing now. With all the miles I've put on this thing with a stock engine. Driving it everywhere I went at full throttle. It's just different.
    With the new engine, things feel much more modern. It revs quicker. Makes good power. I maybe give it a 1/8th throttle and im off, a 1/4 throttle and im flying! It's just so so different. The car feels like a hot rod now. It's completely changed things.
  24. railcarmover
    railcarmover
    8EA5FC29-9404-4ED8-ABDB-99DBC0BA5DEB.jpeg 74A96F31-3D4C-44D3-AC48-61A95DA39872.jpeg Bought another ch***is to waste time and money with. The plan is to make a fool of myself breaking expensive parts racing others doing the same thing.
    Hung fresh woven shoes on the front, a 5 leaf reverse eye front spring and tube shocks all the way around, Mechanicals,cast drums and Teds floaters..got them adjusted correctly and she stops pretty good for rod brakes.
  25. V4F
    V4F
    from middle ca.
    i have had several pulleys like that . finally went to a billet steel pulley .. no more trouble ...... steve
  26. I stumbled upon photos of this Gemsa-headed Donovan engine built by @320ciabone. It's hard to see, but the engine has a front distributor drive which I'm led to believe is a KONG piece.
    As far as gears, does anyone know what would be used to spin the distributors at cam speed? I've got castings for a Kong front cover, and distributor stand. Gemsa Donovan 1.jpeg Gemsa Donovan 2.jpeg Gemsa Donovan 4.jpeg 345020309_689935839602310_6494680004290324892_n.jpeg
  27. same gear set as a flathead V8 or Mod "T"
    Retson the Racer and Crazydaddyo like this.
  28. V4F
    V4F
    from middle ca.
    did you make it ?
    Hitchhiker likes this.
  29. Dan from Oakland
    Dan from Oakland
    Retson- lots of stuff MIGHT work as John mentioned. 1st step is to figure out what the center distance is between the cam and distributor shaft. Figure that out, and the rest is pretty easy. Speedway has the V-8 gears if you want to poke around in dark. I'll post the v-8 center distance later.
    The 49-53 Ford V-8 distributor gears run on a 1.110" center distance
    GuyW likes this.
  30. Savage Coupe
    Savage Coupe
    from Washington
    I have a COOK B side cover. It has a thick rubber type gasket. Anyone know where I might find a replacement?
    Thanks. 33C88DC0-0C83-4482-A429-89C53751F3F2.jpeg DB427BB7-93C9-4F61-97A1-1EA6A12A4F34.jpeg
    Old Dawg likes this.
