Technical MC actuation rod angle
Discussion in 'The Hokey Ass Message Board' started by seb fontana, Dec 21, 2022.
  1. seb fontana
    seb fontana
    from ct
    At present the MC actuation rod angle is 0° at mid stroke. By my calculations if I move the rod pivot point .375 closer to the pivot point of the brake pedal I can get about 20% less pedal effort with around 1/2 more pedal movement. So at mid movement the rod will be at about 5° angle to the MC. Angle acceptable?
    Lloyd's paint & glass likes this.
  2. Dang brother! You make me feel like I don't put enough thought into my stuff!
  3. jimmy six
    jimmy six
    As long as the rod does not come in contact with MC I don’t see a problem. I drilled a hole in my pedal to help with pressure. I put a plug (cut bolt shank) in the existing hole. I used fender washers on each side of the new hole to make sure the plug did not fall out. There was not much material left between the 2 holes.
  4. seb fontana
    seb fontana
    from ct
    Sorry, don't mean to. Toolmaker curse. At 74 my brain still works ok, [maybe not, got a puppy], the rest of me not so much. :)!
  5. pprather
    pprather
    I've moved the rod pivot point to get a better pedal ratio. When I did it, I drilled new holes, so the master cylinder moved the same distance and kept the m/c rod level.
    It was a good modification for my rod. I put a LOT of miles on it with an improved brake pedal feel.
    Here's a pretty good article:
    https://techtalk.mpbrakes.com/how-to-series/calculating-pedal-ratio
  6. X-cpe
    X-cpe
    If there isn't room to move the master cylinder up, you could make or buy a tapered shim to change the angle of the master cylinder slightly to get back to 0*.
    seb fontana and BJR like this.
  7. Remember to account for the reduction in pedal force (F x cosine of 5 degrees)......if you want to be technically accurate......
  8. BJR
    BJR
    If the master has a deep hole in the piston that the rod goes into, make sure the rod doesn't touch the sides of the piston at any point of the pedal travel.
    seb fontana likes this.
  9. jimmy six
    jimmy six
    Huh? If the rod doesn’t contact the piston you never going to stop.
  10. seb fontana
    seb fontana
    from ct
    I lose .4 lbs?
  11. seb fontana
    seb fontana
    from ct
    He means anywhere other than at the end of rod.
  12. BJR
    BJR
    I didn't word that very well. I meant make sure the rod does not contact the side of the piston if the piston has a deep hole for the rod to go into. I fixed my original post.
    Thanks for catching that.
  13. Depends on the pedal pressure required to stop the car.......
  14. seb fontana
    seb fontana
    from ct
    Sorry should have said .4%?
