Mcculloch supercharger help
Discussion in 'The Hokey Ass Message Board' started by Mengestwinspeedshop, Oct 16, 2009.
  1. Mengestwinspeedshop
    Mengestwinspeedshop
    from Santa Rosa
    I just picked up a Mcculloch supercharger for my 27 chrysler. I have a 318 poly motor in it and am wondering about the carburetion i will need. i was hoping to run a 51 Merc carb would this be possible or do i need to make a turkey pan, or can i do something to the carb to make it work???
  2. panic
    panic
    a 51 Merc carb
    And... what is that?
  3. el Scotto
    el Scotto
    from Tracy, CA
    Its simple, really.
    Get a decent Holley 650 mechanical secondary four barrel, you will need it. I heard Carter/Edelbrock carbs can be made to work too.
    Next, you'll need to make/fab a carb hat to get the air into the carb, and then make sure the air doesn't sneak out through choke rod p***ageways or throttle shafts.
  4. MengesTwinCustoms
    MengesTwinCustoms
    This is what the 51 mercury carb looks like. Everything is enclosed inside the case.
  5. R Pope
    R Pope
    That's a teapot, AKA a Towering Inferno. Throw it as hard as you can against the nearest brick wall! Then go find a good four barrel and build, yes, a turkey roaster around it. Remember that your fuel pump has to put out more pressure to overcome the blower boost.
  6. shoprat
    shoprat
    from Orange, CA
    We used to pressurize the carb as mentioned above. Used a second fuel pump
    when in boost mode. They work quite well.
  7. Abomination
    Abomination
    LMAO!
    You rule, panic. :D
    ~Jason
