Hot Rods McCullough supercharger on flatty
Discussion in 'The Hokey Ass Message Board' started by Custom Riviera, Nov 28, 2017.
  1. Custom Riviera
    Custom Riviera
    Hi folks,
    I bought a '36 Ford with a McCullough supercharger model 38F. The driver side upper radiator hose was squashed and I tried to build a plumbing solution. Any Hamber's have a prettier solution for this plumbing quagmire? I'd love to hear from anyone else running a post '38 FOrd with a McCullough supercharger in a '36 Ford.
    Thank you!
  2. WTF really
    WTF really
    Can I see a picture of the other side please I just got a 39M and I think it plums differently.
  3. FritzJr
    FritzJr
    You have a fairly late version of the blower. The earlier models used much smaller water hoses in a by-p*** arrangement. The earliest models had not water flow in the blower housing. I thing that you can have the hose go directly from radiator to the head with a smaller tube feeding the blower. See the attached picture.
  4. ROADSTER1927
    ROADSTER1927
    This is my 1937 super charger. I believe the 1938 is just about the same except the reinforcement under the drive snout is made on an angle instead of straight. super 002.JPG
    BanjoBoy likes this.
  5. WTF really
    WTF really
    The 39s have a small hose that tees into the left radiator hose. 20171107_125927.jpg
  6. WTF really
    WTF really
  7. Custom Riviera
    Custom Riviera
    WTF really, Here's a pic of p***enger side from a couple of weeks ago, I've since relocated the oil filter and coil.
    FritzJr, Perhaps I could feed the supercharger with smaller hoses, but I think that compromises the design intent, even if earlier versions got by with smaller hoses. Maybe a solution would be to move the radiator port to the back side of the radiator, then the top of the supercharger could be fed more directly. I'm not sure if I would change both sides of the radiator or just one, or how that would affect cooling.
    Roadster1927, cool pic of your 1937 unit, quite a few differences, small pipe exiting supercharger gear box, rear belt drive, oil cup shaft lube, its really very different.
    farmalldan and WTF really like this.
  8. Custom Riviera
    Custom Riviera
    They sure made a lot of changes, 37, 38 and 39, I wonder what a 40 looks like?
    Anyone have thoughts on moving the driver side radiator outlet from bottom to back side?
    Anyone know how many of this style McCullough supercharger were made and for how many years?
  9. WTF really
    WTF really
    37 thru early 40 and it only said more than 5000 produced.
  10. FritzJr
    FritzJr
    Here is a picture of a later unit with the smaller hose connection for the water outlet. I think this is a Model 40M.
  11. WTF really
    WTF really
    That one looks just like my 39M
  12. FritzJr
    FritzJr
    Here is a picture of a later unit in a '36. The blower is the model with the large hose connections in the upper housing and lower housing. I believe this is how this model blower was supposed to be plumbed.
    WTF really likes this.
  13. Custom Riviera
    Custom Riviera
    FritzJR,
    That's it, modify the radiator and eliminate the crazy plumbing.
    I'd love to see a pic of the p***enger side.
    Thank you so very much!
