Technical Mech. Speedo Cable Lengths?
Discussion in 'The Hokey Ass Message Board' started by dirtybirdindian, Mar 21, 2015.
  1. dirtybirdindian
    dirtybirdindian
    I need a longer Mechanical Speedo cable since I recently did a T5 swap. I nee one about 66" long +/-. Parts place could only find ones that are 63" and then 80".
    Does anyone know of one that will be closer to 66"? I suppose 80" would work but it will be quite a bit longer than necessary.
  2. geoford41
    geoford41
    from Delaware
    Go to your local NAPA parts store and ask the "older" counter guy to look up a list of speedo cables that fit the trans output (you can measure that) and the speedo which I think are usually 7/8" I needed one 76" for my 40 coupe and got one around 84" which works but required some "re-routing" to make it fit. I believe that the NAPA web site gives lengths and end connection threads so also check that out.
  3. prewarcars4me
    prewarcars4me
    from Bhc, AZ
  4. fordor41
    fordor41
    get the 80" cable, cut it with a sharp cold chisel and epoxy the end on and good to go.
  5. dirtybirdindian
    dirtybirdindian
    I have an 80" one but it doesn't have a threaded end at the gauge...supposedly you suppose to just push it on ( it doesn't work that well ) So you think I can cut that end off and put the original end that threads into the gauge on the new cable with epoxy and it will hold up??
  6. Paul
    Paul
    Editor
    there should be a speedometer shop not too far from you,
    they can make up any combination of ends and lengths for you
    Crazy Steve likes this.
  7. Yep, there's still some of those around, not too expensive either (or at least wasn't the last time I had one made).
