Mechanical aptitude test
Discussion in 'The Hokey Ass Message Board' started by barry2952, Oct 26, 2007.
  1. Yo Baby
    Yo Baby
    I scored an 84 twice,but the second time at least I knew how to see what I got wrong thanx to LIV42Day.LOL
  2. Hell, I thought "I was cutting a fat hog in the ***" I was up to question 32 before I got a message saying that a answer was incorrect. I didn't get another message, so I was feeling kind of smug until I saw the score 78%. Time to grab a big ole bite of humble pie.
  3. I got a 74%... I really have NO business building a car.
  4. flathead A
    flathead A
    from michigan
    I GOT A 78 :confused: ELECTRICAL AND SOME OF THE GEARS GOT ME.
  5. Da Tinman
    Da Tinman
    84% here,, But my wife "Helped"
  6. gas pumper
    gas pumper
    this dumb old fart hit an 88, that's six wrong out of 50. Not bad for flunkin out of GMI cause of physics:)
    Frank
  7. I got a 92. I wasn't sure on that one with about five pulleys stacked up.
    A couple questions had artwork that was a little confusing. Like the rack and pinion one didn't specify if the pinion was fixed or if the rack was fixed. Or the one with a "Piston" that looked like the head of a nail. Was the drawing representing fluid being pushed by a piston of that surface area to a smaller piston, or was that supposed to be a big nail-head shaped piston?
  8. langy
    langy
    92 for me but i know where i went wrong.
  9. yblock292
    yblock292
    78% just printed it and it will show you the right answers..... missed dumb ones.
  10. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    90% ... I know I botched the first one with the batteries.
  11. lucky_1974
    lucky_1974
    90% damn fan question :)
  12. Gruizer54
    Gruizer54
    76% ouch, now i know why my car isn't running yet!
  13. Kramer
    Kramer
    86% for me. At least I p***ed. Probably could have done better if I had thought about some of them more before answering.
  14. Noland
    Noland
    I failed
    wish I knew wiring scamatics
  15. D.W.
    D.W.
    from Austin Tx.
  16. GrantH
    GrantH
    I got a 66, the fan question is misleading. Same direction can mean 2 things, the same way literally, same way of the fan motor. Facing each other technically one would be counterclockwise and one would be clockwise.
    I also wasn't aware atmospheric pressure brought air into the cylinders, I always thought "suction" did it. Obviously not.
  17. lucky_1974
    lucky_1974
    The cylinder question got me also...I still say its suction:D
  18. GrantH
    GrantH
    They need a lesson on calculating percentages as well. I missed 16 out of 50. So I got 34 out of 50. 35/50 = .68*100=68%
    They gave me a 66.
  19. GrantH
    GrantH
    if you click the hour gl*** on your results page, it lets you go through it to see the correct answers.
  20. 82% not too bad for someone trained to work on people! I'm happy, now Ill put an emergency medicine one up (Doc your not invited) lets see how well you guys go.............
    Nah, just kidding. I think I would fail that too, and I ave a Doctorate in pre hospital care!
  21. Liv42day
    Liv42day
    I say the question regarding the atmospheric pressure has technically two correct answers. Yes the pressure brings in air. Only because the piston pulling down creates the low pressure in the cylinder so the higher pressure outside wants to push its way into the cylinder. But yes the piston creates a sort of vacuum inside the cylinder. Thats my way of describing it.
  22. GrantH
    GrantH
    I took it as a piston, pushing onto a rod, or a "nail shaped piston". surface area was like 3 times more on top, so you multiply the pressure by 3, as you cut surface area down that much.
  23. GrantH
    GrantH
    It's like saying the fact the combustion chamber is actually pressured on the combustion stroke has not help on pushing it on the following exhaust stroke. I believe it does ;) Plus, the piston rings aren't letting air past them, or else there would be no compression, not constant anyways. Therefore it's PUSHING it out...same can be said for it ****ing air in. Least that's how I see it.
  24. Liv42day
    Liv42day
    Once again while taking the test if you click the ****on to the far left of the submit ****on as you go through the test you can see correct and incorrect answers.
    As far as your percentage is concerned GrantH we do not know how each question is weighted. Some questions are much harder than others and may be considered 2 points instead of 1 or something like that. Go for the 50/50 and then it doesn't matter. ;-)
  25. Kramer
    Kramer
    But,,, because the pressure is higher outside it is pushing the air in.
    However I do agree with you, but I did learn it as things don't get ****ed in, they get pushed in.
  26. 40Tudor
    40Tudor
    from MN
    Just between you and me....96
    I was lazy on the block and tackle and underestimated their understanding of things on the piston.
    What's the prize?
  27. Groucho
    Groucho
    86. I think I really got 100, but 14% of the questions are wrong. hahahha
  28. Liv42day
    Liv42day
    You are correct. And I agree. I also got the question correct. There were just comments regarding "suction" in the thread. Thought I would toss in a small explanation.
  29. Phil1934
    Phil1934
    90% for a civil engineer
  30. oldguy829
    oldguy829
    84, I can not read a schematic
