"Mechanical" Brake Light Switch (How you mounted)
Discussion in 'The Hokey Ass Message Board' started by fordstandard, May 18, 2012.
  1. fordstandard
    fordstandard
    Can I see how you mounted -Mechanical Brake Light Switch in your ride
    that does not have a hanging brake pedal.
    What parts did you use--supplier/part numbers please
    Pics would be helpful
    My Shoebox Ford has frame mount dual master cyl -- i would like to go with Mechanical Brake Light Switch )
  2. fiddy
    fiddy
    No pics, but my 50 chev has the pedals through the floor and the switch was mounted on the firewall underneath the column from factory
  3. tfeverfred
    tfeverfred
    I mounted mine on the floor, next to the brake arm. Bent the switch arm, so it activates at the slightest brake pressure. Works great.
  4. GassersGarage
    GassersGarage
    My '51 Chevy has the same thing, however, my '49 Ford has a hydraulic pressure switch.
  5. mj40's
    mj40's
    Chevy pickup switch mounted off the brake arm on my 40 Ford pickup.
  6. fordstandard
    fordstandard
  7. fordstandard
    fordstandard
  8. 55 dude
    55 dude
    to the moderators i wasn't saying this thread was SPAM their was some weird posts going on about a body being blasted from some new guy!
  9. Cole hersee makes a left and a right, I believe standard ignition makes them too.
    '54 Ford panel truck
  10. tfeverfred
    tfeverfred
    Still haven't figured it out yet?
  11. fordstandard
    fordstandard
  12. That switch looks identical to the one in my 55 Pontiac.
  13. A few cars/trucks run them in stock form (late 50's chevy truck). Aftermarket ones you can choose left or right arm and normally open or normally closed.
    I had that one in the garage, when it goes out I'll find one with the arm exiting out the other side so it won't get water inside it.
  14. mgtstumpy
    mgtstumpy
    I run this vertically under my brake pedal on the firewall side. Adjustable. I also run the transmission lock up through it as well. No issues. Similar to #5 but 90 degrees difference.
  15. 40FordGuy
    40FordGuy
    You can also install one under the clutch pedal for a start safety switch,....GM did that on std shift cars in the late 60's. The clutch pedal must be depressed, in order for the starter to operate. My 40 pickup has one.
    4TTRUK
    pecker head likes this.
  16. swe64
    swe64
    pontiac 1957 have them on cars without powerbrake and gmc picup 1955-59
  17. scrappybunch
    scrappybunch
    from nj
    Why not plumb in a hydraulic pressure switch, no fussing with brakets and linkage.
    nochop likes this.
  18. new version goes out a lot and sometimes you get a switch that doesn't light up under a lite pedal push. Too much variance in quality.
  19. Bump Stop
    Bump Stop
    from USA
    Reviving this thread because I need to order a mechanical brake light switch and not sure if I need the RH or LH model. Can someone please tell me which way each turns on - toward the mounting base or away from the mounting base? Can you pull them apart and reverse the arm?
  20. swe64
    swe64
    lighths go on when spring is pressing the bar down on gmc bar goes on top of brake pedal.
    when you brake spring inside kontakt press bar down and let 12/6 p*** to brake light
  21. tfeverfred
    tfeverfred
    Both of those are in the closed position or off. You just need to decide which one will work for you. That picture is awful small.
  22. ebfabman
    ebfabman
    This is how I mounted the brake light switch on my 50 Merc. Upgraded to a dual res m/c. I used a wiring harness from a 71 c10.
  23. Bump Stop
    Bump Stop
    from USA
    I really like that setup. I'll order an inline switch and do it that way. Thanks!
  24. We fought this on our 32 and finally figured a brake line pressure switch was the simple way to go for us....
    nochop likes this.
  25. 24riverview
    24riverview
    Afraid I have to disagree with Tfeverfred on that one, both shown are "on" (lever away from base). And the right or left hand thing is only a matter of where it fits and which way you want terminals to point, up or down. And no, I 've never seen one you can reverse the arm on.
  26. ebfabman
    ebfabman
    Another angle
      484.8 KB
  27. 40FordGuy
    40FordGuy
    That underfloor switch also makes a great start safety switch, when mounted under the clutch pedal.
    4TTRUK
  28. tjet
    tjet
  29. tfeverfred
    tfeverfred
    Thanks! I said those pics were small.:D Had to remember how I mounted mine.
  30. Dennis D
    Dennis D
    Like this. Dennis D
