Mechanical brake rod query
Discussion in 'The Hokey Ass Message Board' started by airnwater, Sep 25, 2012.
  1. airnwater
    airnwater
    Hi
    ' 30s car with mechanical brakes , rods running front & rear are approx
    3ft & 4 ft long & 5/16 in diameter.
    They are damaged + worn , just wondering what type of steel are these
    usually made from ( they are in tension when brakes applied )
    Would they need to be eg EN24 or would silver steel be ok or ..?
    Also the clevis pins at the ends of the rods ,are these typically hardened ?
    Thanks in advance for any information.
  2. airnwater,
    I made some for an A bone in the '90s out of meralloy, it is like soupped up cold rolled steel I suppose. The fella is still running it and actually drives it to and from work when the weather permits.
    I don't know that Ford used anything special as in some sort of an alloy, and I would think that cold rolled steel may work real well.
  3. It's just goo high quality steel. Welds like a dream. The rods pull to apply brakes.
  4. F-6Garagerat
    F-6Garagerat
    My brother bought some 32 brake rods from one of the repro places. They are made of Craptanium. They were expensive and the quality was horrible. A 3 year old with a grinder could have done better. You can make better at home.
  5. Saxon
    Saxon
    from MN
    Synders has good quality ones. forged ends and at a decent price (do you want cheap for brake rods?).
    http://www.snydersantiqueauto.com/273
    Whats the damage? are they bent? rods gouged from contact?
  6. airnwater
    airnwater
    Thanks for suggestions so far ;
    Non-Ford so rods will have to be made up , the oversize clevis pins Snyders have may be useful .
