Mechanical Brake Switch
Discussion in 'The Hokey Ass Message Board' started by Voh, Apr 30, 2012.
  1. Voh
    Voh
    Can someone help me with a mechanical brake light switch?
    1-how much does that little arm have?
    2-what do you use to connect the wire to the round post? Will the typical female bullet terminal fit?
    3- can these be found at any local parts stores or are they mail order only (was there a make/year that used these for lookup)?
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Question 1 has no answer 'cause it doesn't ask anything concrete.
    Question 2 : Typical female bullet fits. Yes.
    Question 3 : Early Chevy pickups, just look in the stoplight switch section of the illustrated Standard Ignition( whatever line your store carries)electric parts catalog.
  3. indyjps
    indyjps
  4. Black_Sheep
    Black_Sheep
    My '68 GMC van had a brake light switch with an arm.
  5. Voh
    Voh
    Sorry
    1 - how much movement does that arm typically have?
    Don't know what the hell I was typin the first time
  6. Voh
    Voh
    The other one I was wondering about was the pull style that you see a Bunch on bikes/choppers. Would that work on the brake pedal?
    I am collecting parts to wire a guys '46 Chevy. It currently has no brake switch installed. Trying to get a game plan for that part of it.
  7. Bears38
    Bears38
    I'm running two of these switches on my '49 , one I converted to be on when brake pedal is "up" to lock up my converter on the 700r4 . You can cut , bend or weld the arm to fine tune it too your application !
  8. fordcragar
    fordcragar
    from Yakima WA.
    You should be able to buy one of the stock brake light switches almost anywhere. Rockauto has them on their website for under $6.
  9. mgtstumpy
    mgtstumpy
    Similar,room for adjustment
