Hot Rods Mechanical Fan
Discussion in 'The Hokey Ass Message Board' started by LEE CHRISTENSEN, Aug 16, 2019.
  1. LEE CHRISTENSEN
    LEE CHRISTENSEN
    Was wondering if I run a Mechanical fan below the radiator about 1 1/2" matters?
    And are there any consequences to doing so?
    scrap metal 48 likes this.
  2. Texas Webb
    Texas Webb
    As long as you have 2 or more inches of clearance,hoses etc. also a fan shroud will help a lot pulling air.
  3. dann57
    dann57
    from Missouri
    My fan sits about 2 inches below radiator , I have about 1/2" to 3/4" clearance between fan and bottom rad hose . Im using a 16" mechanical fan. My temp was running a little high so I added a fan shroud and lowered temp . I'm not saying this is how it should be done but this works for me.
    scrap metal 48 and Frankie47 like this.
  4. Jalopy Joker
    Jalopy Joker
    running fan larger than radiator does not benefit cooling - better to run a shorter fan with a full shroud - LEE CHRISTENSEN=you need to change your avatar
  5. LEE CHRISTENSEN
    LEE CHRISTENSEN
    Just one of the cars that I own
  6. Jalopy Joker
    Jalopy Joker
    LC - so, post pic of a '65 or older traditional one
  7. woodiewagon46
    woodiewagon46
    from New York
    A shroud is a must for optimum cooling.
  8. scrap metal 48
    scrap metal 48
    I'm just glad your using a mechanical fan...
    Just Gary likes this.
  9. Dave Mc
    Dave Mc
    The engine returns the hot water to the top of the radiator , cooling should be focused up to the top , that is why a shroud is preferred .
