Technical mechanical fuel pump for sbc
Discussion in 'The Hokey Ass Message Board' started by bodymanmp, Dec 29, 2022.
  1. bodymanmp
    bodymanmp
    whats the best mechanical fuel pump for sbc high performance??
    for 327,350 hp engine
    Deuces likes this.
  2. wheeltramp brian
    wheeltramp brian
    I've had very good luck with the Carter Street pumps. They put out about 5 PSI and don't hold pressure after they're shut off. I forget the gallons per hour but it's plenty for a street car
    Tim, Deuces, Kelly Burns and 4 others like this.
  3. woodiewagon46
    woodiewagon46
    from New York
    Carter makes a good product. I would make sure that the base is screwed on, enabling you to "clock" the base so the outlet is where you need it to be.
  4. impala4speed
    impala4speed
    I have also had good luck with Carter pumps. When I got my BBC done I installed a Summit brand pump. Seemed to be a decent pump but not much cast material around the inlet fitting area. Used it for awhile but when I went to change to a different fitting the body of the pump cracked off. Next tried an expensive Edelbrock pump. Was OK for about a month then the pressure dropped from about 5-6 PSI to aprrox. 1 PSI. When I returned that one I went with the Carter. So far so good.
    Deuces and mad mikey like this.
  5. saltracer219
    saltracer219
    I just went through this with a Buddy of mine. He started with a new Carter and had driveability issues. We checked pump pressure, it varied between 8 and 12 p.s.i.. He went back to the parts store and came home with a new Delphi, checked pressure, 12 p.s.i., took it back for a refund. As far as I can tell all of these new replacement pumps are Chinese manufactured no matter what name they have on them. He then went with an Edelbrock made in U.S.A. street performance pump that is clockable, (the others are not) the Edelbrocks are pricey at around $140 but it puts out a consistant smooth 6 p.s.i. but seems to be a quality piece. All seems to be well now....we'll see!
    clem, swade41, Pist-n-Broke and 2 others like this.
  6. DDDenny
    This is the AC fuel pump on my Novas' 327/350 hp engine.
    Sourced from my local Chevrolet parts dept, was many years ago so may need to scan the internet.
  7. mad mikey
    mad mikey
    I have not run a mechanical pump in a long time, but back when I did, had a Carter, a Edelbrock, and a holley, all worked fine. I guess today like lots of parts it can be a **** shoot.
    Deuces, clem, impala4speed and 2 others like this.
  8. BOOT77
    BOOT77
    from Michigan
    I'd aim for like no more than 90gph Holley/Summit has one that size I think, too much pump and your just heating up the fuel. The factory C3 Corvette pump is just under 40gph, has a return and I ran one for bout 375hp But I broke two of the auto parts store pumps(6000rpm shifts). So then went with a Carter strip pump and too much psi, had to use a byp*** reg And deadhead regulators to get it reasonable. The Carter street pump is fine and only needed the byp*** reg But heats the fuel with my stock 3/8 lines(pump reads 400ish deg while the block is 200). So gonna try a 90gph Summit pump with just a byp*** reg.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    :D
    Tim, jimmy six, clem and 3 others like this.
  10. Jagmech
    Jagmech
    What ever you buy, check it with a good pressure gauge. Unless you want the "look" consider an electric pump.
    mad mikey likes this.
  11. impala4speed
    impala4speed
    I believe this to be very true. Just about any product you get, name brand or not, seem to have some real quality issues.
    mad mikey and 427 sleeper like this.
  12. pprather
    pprather
    This is what I've been using for quite a while.
    12355612
    Fuel Pump – Street Performance, Small-Block
    Unfortunately, I think it is I longer available.
  13. I just went through 3 N.A.P.A. Carter pumps and another Delphi brand from N.A.P.A. that I swore was a Carter re boxed under a different name. All junk. Carter is a "used to be" good product, not any longer. Edelbrock part #1721 Made in the U.S.A. cured my problem. There high-performance pump is part #1722. Yes you can change the clocking of the bottom on both pumps. To heck with the price, it's a Quality pump.
    saltracer219 and 427 sleeper like this.
  14. UNCLECHET
    UNCLECHET
    I have a 65 Corvette with an L79. I put on a stock replacement pump from Ecklers a few years ago. Ran fine for awhile and then **** the bed. At a Friday night drive in car show. I had to call a friend in to tow me home. The tow of shame......Anyway the pivot pin backed out of the pump arm and that was why it quit. I think I put an AC pump on after that. It's been fine for a couple years now. But it's all a **** shoot nowadays. This pump hasn't had any issues but I don't really beat on this car. I'll run it up thru the gears now and then but I don't wring it's neck like it was new. The engine has never been apart and she's old.
    Deuces likes this.
  15. TA DAD
    TA DAD
    from NC
    On this budget build I installed a $19.99 Precision pump from Oreillys.
    I have driven it all summer with no issues. Above 6 grand all the time. If and when I upgrade the fuel pump I will use a ALLSTAR brand pump. That is a common pump around here on round track cars. They are about $180.00. I have heard more than one snicker about my fuel pump and distributor.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Another source would be to go to a marine grade mechanical unit. Ya I know I went another direction but California leaves little options so I went with what works best for a carbs that does not have Holley type squirter pump that fairs well with evaporation for ease of start up.
  17. AHotRod
    AHotRod
    I've been using Carter M6900 Performance pumps for 50 years on my Chevy 327-400 small blocks, Maximum PSI is 6# and flow 120 GPH. I highly recommend it.
    The non-performance pumps sold at any Auto Parts store are a total ****-shoot, I've had some that flooded the carburetor, set up a fuel pressure test and found them producing 10-12+ PSI.
    Deuces, clem, Just Gary and 4 others like this.
  18. 54FISH
    54FISH
    MY BIGGEST ***** with Edlebrock is CUSTOMER SERVICE !? NO answers , NO replies , CRICKETS ! Maybe it's me ,words out I'm an ***hole I guess ,but damn if I'm going through that & spending hundreds- thousands with them . Just my OP.
  19. 67drake
    67drake
    from Muscoda WI
  20. I've never had trouble with any of the generic O'Reilly pumps
  21. 1biggun
    1biggun
    Have had a Carter on my Vette since 91 so now after posting this t will likely fail .
  22. Lone Star Mopar
    Lone Star Mopar
    FYI those that need a pump that can be clocked. I just bought one from Napa for a 57 Chevy. Cant remember the brand but it was inexpesive compared to an Aftermarket. Cant speak to the PSI, but It works fine on my ol 327 4bbl.
  23. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Still a fan of the old reliable M6624 Carter. Usually available at any parts store.
  24. hotrodA
    hotrodA
    Carter M2468 can be clocked and has ports in the main body if you’re cramped for space below.
    Deuces likes this.
  25. 325w
    325w
    Well I bought four of the old Carters at Summit. All of them failed to work out of the boxes. Ended up with the cheap old Carter.
  26. When I went through this with saltracer219 I learned it's a well know issue for the Guys behind the parts counter. I asked why NAPA corporate doesn't go to the supplier and get them to resolve there build problem. I was told most customers just put an inline regulator on and don't return for refunds. It's a strait up win win for them, the defective pumps sell and sales increase with the in-line reg. Now that's a F-ed up program!
    427 sleeper likes this.
  27. 1971BB427
    1971BB427
    from Oregon
    I've gotten to the point where I wont run even a mechanical fuel pump without using a pressure regulator after it. Just seen too many issues with pumps that put out pressures high enough to flood carbs when they over pressure the float needles.
    Deuces and 427 sleeper like this.
  28. That just seems wrong but does cure the problem and that seems to be NAPA's plan. Bump up those sales! They should sell the pumps at half price since they are only doing 1/2 there designed job!
  29. saltracer219
    saltracer219
    Well, that may get the job done but if the pump was right in the first place it woulden't be necessary.
    Pist-n-Broke and 427 sleeper like this.
  30. 67drake
    67drake
    from Muscoda WI
    With the RobbMc you are dealing with the owner or his tech guy. No **** shoot/keep your fingers crossed you get a good one. It’s expensive, but a quality USA made product from a small company. IF it gives you any problems they will fix it and stand behind their product.
    Deuces likes this.
