Technical mechanical fuel pump for sbc
Discussion in 'The Hokey Ass Message Board' started by bodymanmp, Dec 29, 2022.
  1. 1971BB427
    1971BB427
    from Oregon
    I've seen too many of all brands of mechanical pumps that had higher pressures than carbs can handle. And too many guys having flooding issues and rebuilding, or replacing carbs only to have the same issues still!
    I also always install a fuel pressure gauge on all of my builds so I can easily see what the fuel pressure is at a glance. These issues don't just happen with cheap pumps, or old pumps; they happen regardless.
    Deuces, saltracer219 and Kelly Burns like this.
  2. saltracer219
    saltracer219
    I get it and totally agree. I do the same thing but my point here is that this never used to be a problem with quality U.S. made parts when people took pride in their work. There are not many parts to a mechanical fuel pump, it seems that they could get the spring tension for the relief valve within specs.
    Pist-n-Broke likes this.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Guess Edelbrock tech forgot about the internal valves in the pump ?
  4. gimpyshotrods
    gimpyshotrods
    Stuck check valve.
  5. 54FISH
    54FISH
    Ya think ? Even after it runs good for about 10 minutes ? I mean I gotta believe uour right ,it's gotta be in the pump .the tank & feed line is out of the equation , the outlet line from pump to carb is new. Thanks ,I'm thinking of going with a higher psi pump ( 6-7, quickfuel or holley) .but still want to know wtf is causing this . Have a good one bud & thanks very much!!
  6. impala4speed
    impala4speed
    I had the same problem with an Edelbrock fuel pump in my BBC. The first pump I used was a Summit unit, which worked fine but when I went to change the fuel inlet fitting that part of the casting broke off. Apparently a common problem with these pumps. Next up was the Edelbrock unit. I only had it for a few weeks when it started doing the same as yours, fuel pressure dropping from about 6 PSI to about 1 PSI. Was able to return this one to Summit and purchased a Carter pump which is still working great.
  7. 1971BB427
    1971BB427
    from Oregon
    I've seen this before and my thinking is tolerances changing as the engine heats up and transfers heat to the pump body. If things are marginal clearance when cold, and then change with temperature it can cause this sort of problem.
    I've seen this with some brands of pressure regulators also. Set them cold, and once they got heated from under hood temperatures the pressure drops 2-3 lbs. I try to mount my regulators down low towards the front of the frame rail so engine temps up higher wont affect them as much.
  8. 54FISH
    54FISH
    Thanks ,I'm not running a regulator , but I agree heat can change characteristics . The quick fuel carb suggest 6.5psi & for 2000 miles on build with the edelbrock ( never above 5psi) so I'm thinking get something 6-7psi & be done with it .but I'm opening it up cause I want to see what might be happening here .+ I'm done with edelbrock ,their customer service blows IMO . Thanks again!
  9. 54FISH
    54FISH
    Thanks I got 2000 miles on pump since new build .And I don't even know if it was new , NOT sure if it was used & put back on shelf at buddies cousins shop so..... we will C .I'm curious as to what's going on here .I m gonna search for clockable 6-7 psi pump either way .thanks again brother!
    Okie Pete and impala4speed like this.
  10. pprather
    pprather
    Carter M6900 as advised above.
    lothiandon1940 and Just Gary like this.
  11. 54FISH
    54FISH
    YOU WERE RIGHT! sliver of aluminum holding check valve open . Thanks !
    lothiandon1940 likes this.
  12. ClayMart
    ClayMart
    And to a degree at least, when some employers took pride in their employees.
    impala4speed likes this.
  13. wheeltramp brian
    wheeltramp brian
    The Carter m6900 can't be bought anymore,used my last one on a customer's car. Now I need another good pump,suggestions?
  14. AHotRod
    AHotRod
    Another victim of private equity firms, so sad, Carter was a 115 year old company .
    Carter Fuel Systems permanently closed its historic manufacturing plant in Logansport, Indiana, and went out of business on April 30, 2026, after its parent company, First Brands Group, filed for Chapter 11 bankruptcy
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Because of this I’ll be visiting the marine shop to ask about MerCruiser 305,350 units.
    67drake likes this.
  16. Driver50x
    Driver50x
  17. hotrodA
    hotrodA
    As Carter, aka First Brands Group is no more, I ordered a spare M2468 from Rock Auto to carry in my 40, just in case. $23 plus shipping. “Warehouse closed” in their listing.
  18. wheeltramp brian
    wheeltramp brian
    They won't ship the pump to me in ca....
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That’s BS! Just because they don’t have do***ents in place.
  20. hotrodA
    hotrodA
    Have them ship it to me and I will forward it to you.
  21. deathrowdave
    deathrowdave
    from NKy
    Watch the pivot pin on this pump . Through time they seem to loosen and work their way out , leaving you stranded .
