Mechanical fuel pumps?
Discussion in 'The Hokey Ass Message Board' started by lownslowtexaco, Dec 29, 2008.
  1. lownslowtexaco
    lownslowtexaco
    from athens,tn
    Are there some factory mechanical pumps that are better than others? for example would the fuel pump on an mid 80's camaro be better and pump more fuel than say a pump on a 120hp 305? any input would be appreciated
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    In most cases no. In your Camero in a certain year most likely all small blocks would use the same pump . The size and positioning of the fittings are usually the big differences. I know some year high proformace apps would have different pumps, mostly as I remember this was in the 60s. And that might have been just a stronger internal spring for higher pressure.
  3. lownslowtexaco
    lownslowtexaco
    from athens,tn
    ok thanks for the reply ive just always wondered was gonna buy a new pump and figured i would get the better one if there was such a thing
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    I believe the only difference you'd find in any of the SBC carbureted engine fuel pumps is the construction (crimped together banded housing or screw-together housing), physical size and number of hose outlets/inlets on them.
