Projects mechanical speedometer to electronic output gearbox
Discussion in 'Traditional Hot Rods' started by Johan Hansson, Mar 29, 2024.
  1. Johan Hansson
    Johan Hansson
    hello my friends
    would need tips on how to get my speedometer to work.
    Has a mechanical gauge and a Borg Warner T5 gearbox with electronic output. What tips do you have for putting this together? is it the speedhut speedbox that applies or do you have another suggestion?
    Happy Easter
    Rase Davis likes this.
  2. Jack E/NJ
    Jack E/NJ
    from NJ
  3. 51504bat
    51504bat
    @e1956v to the white courtesy phone
  4. hrm2k
    hrm2k
  5. goldmountain
    goldmountain
    There was someone who posted on the ultimate t5 thread who did the necessary machine work to convert the extension housing over to a mechanical speedo drive. Not quite sure how to go back there and look him up.
    hrm2k likes this.
  6. '29 Gizmo
    '29 Gizmo
    from UK
  7. pprather
    pprather
  8. pprather
    pprather
  9. '29 Gizmo
    '29 Gizmo
    from UK
  10. e1956v
    e1956v
    Alliance Vendor
    My supplier for the GPS box quit production so I no longer carry anything. I like the GPS to cable drive solution and Speedhut make a good product. Cable X is good, just more of a pain to dial in calibration wise.
    51504bat and Algoma56 like this.
  11. gimpyshotrods
    gimpyshotrods
    GPS doesn't work under stacked-deck bridges, or in tunnels.
    I run Dakota Digital EDC drives in customer builds.
    Push the ****on, drive a measured mile, push the ****on again. Done.
  12. gimpyshotrods
    gimpyshotrods
    @Kato Kings
  13. Johan Hansson
    Johan Hansson
    to dakota, is it only + and - that is needed or do I need to put something into the vss connector in the gearbox? here read differently so no good answer.
  14. gimpyshotrods
    gimpyshotrods
    You connect two wires to the VSS, in addition to the power wires.
    VSS wiring pigtails are available online for about $10.
  15. Johan Hansson
    Johan Hansson
    do you know if it is possible to measure the output in the gearbox, don't know if it is working
    what site have you found for 10$
  16. jaracer
    jaracer
    A buddy of mine built a 51 Riley roadster with a mid-90's Caddy Northstar behind the driver. He used part of a body of a Mercury Mercur which had a mechanical speed and tachometer. The Caddy transmission had an electronic output for the tach and speedo. He had to have the Caddy dash in the wire loom (hidden under the hood) to get the electronics on the engine to work. He took the stepper motor and needle out of the Caddy dash and mounted in the Mercur dash. After a lot of fiddling he got it all to work. Sloan09.jpg
  17. pprather
    pprather
