Technical mechanical tach comparison
Discussion in 'The Hokey Ass Message Board' started by Paul, Dec 22, 2016.
  1. Paul
    Paul
    Editor
    in the shop yesterday just fiddling around,
    had a mechanical tach drive magneto in the distributor machine
    and thought I'd spin the three tachs I had laying around,
    I knew they all worked but thought I'd see how they compared to each other and the tach on the machine itself.
    I was surprised at the results..
  2. squirrel
    Hilarious...welcome to my life, over the past few years. If you're gonna run an old mechanical tach, build a stout engine.
    Paul likes this.
  3. Aaron D.
    Aaron D.
    That just took the faith out of me in my old SW tach.
    Paul likes this.
  4. ago
    ago
    from pgh. pa.
    Get a new bezel and re position the needle. How do know the dist tach is accurate?
  5. AHotRod
    AHotRod
    Most excellent Paul.
    Paul likes this.
  6. Paul
    Paul
    Editor
  7. falcongeorge
    falcongeorge
    from BC
    I was wondering the same thing. I expected the needle bounce at idle, always kinda liked that, it's kinda like blower surge. I was told when I was a young guy that was cable whip, and it only happened at steady rpm, no idea if that's true or an old racers tale.
    But I was SHOCKED that the second tach tested read 1000 rpm low at 7000. Man, I am putting an original late fifties Corvette mechanical tach in my T Tudor with the 283, was planning on running it to 7000, if the Corvette tach reads a 1000 rpm low, I'll be cleaning it up with a broom!!:eek:
    I also have one like the first SW tested, and a moroso like that for my FE.
  8. Oldmics
    Oldmics
    The shop I cut my teeth in did speedo repairs (he NEVER rolled any back :rolleyes:).
    He explained to me that all speedos and tachs were not accurate due to torsionial flex of the wound cable.
    Just sayin what he told me.
    Pretty interesting
    Oldmics
  9. falcongeorge
    falcongeorge
    from BC
    I was just in the shower thinking about this and thought I had observed something about the second tach. Came back and watched the video again and confirmed it. The second tach doesn't show any needle bounce to speak of at low rpm, which in my experience most mechanical tachs do.
    That, combined with the fact that it reads so low, makes me wonder if there's a buildup of gunk in the cable, or possibly in the gear drive at the back of the tach. Just a suggestion, but I might repeat the test and check for heat buildup either in the cable or the gear drive at the back of the tach. Does it feel stiffer than the other two when you rotate the end of the cable by hand?
    If it is full of gunk, and that's exerting a drag on the cable or gears, one of two things could happen if you run it on a vehicle. Either it will loosen up, or it will probably snap the drive cable in the first 10-20 miles...:eek::D
  10. falcongeorge
    falcongeorge
    from BC
    Oh, and love "theme from a summers place" playing in the background, now THATS traditional!:D
  11. Paul
    Paul
    Editor
    the first tach is as found and has a new cable
    the second tach was billed as restored, it also has a new cable
    the third tach and cable are as found
    the tach in the machine is also as found.
  12. very interesting. was the same cable used on all the tachs tested? i have found that having the cable as straight as possible reduces needle bounce. i also clean the cable and housing then use graphite before re***emble. i wonder how the test would go using a single fresh cable. this video makes me want to test mine in a similar manner.
  13. Paul
    Paul
    Editor
    all three tachs have their own unique cables.
    the head ends are specific to each tach and are not interchangeable.
  14. squirrel
    Even a slight kink in the cable will cause bounce. And the cables are NOT making the tachs read wrong...
    SW tachs are magnetic, like a speedometer. The Moroso (Jones Motrola) is centrifugal.
    The SW tach I have from the 80s usually works pretty well, but I left the cable a tiny bit loose at the tach end once, and I think it messed up the bearing. Also if the center part of the cable is a tad too long, it will eat up the tach.
    The Jones tach I have got sticky...it usually works ok if RPM changes frequently, but on a long drive, it will stick in one spot. Not good.
    It would be fun to do a similar comparison with half a dozen electronic tachs, of varying ages.
  15. Paul
    Paul
    Editor
    I think I have a few electronic tachs,
    at least two SW and one Dixco and was thinking of running them, just to see what they do..
    squirrel likes this.
  16. falcongeorge
    falcongeorge
    from BC
    my experience with most older electric techs is that they " overshoot " when the rpm climbs quickly, that won't show in this style of test.
  17. henryj1951
    henryj1951
    from USA
    rev bounce
    ya rev to 4grand and the needle flies up to 5500...ha...lol
  18. falcongeorge
    falcongeorge
    from BC
    Yup^^ great for impressing your buddies, not so great for hitting your shift points...
  19. el Scotto
    el Scotto
    from Tracy, CA
    Well this is interesting, I had been planning on running a cable tach on my roadster.
    Any recommendations or advice before I purchase? I had been looking at used SW or a Jones.
  20. squirrel
    buy several old mechanical tachs, and find a buddy with a distributor machine, or get a good name brand, new, electronic tach also. Do your own comparison testing. Expect to spend money. Sell the tachs that don't read properly on ebay "as is" "for display use"
  21. fleetside66
    fleetside66
    I was mesmerized by it all, as well as surprised. I'd love to see how an electric 60's Sun tach with an EB-9A sender would compare. Thanks for taking the time to do that.
  22. Joe H
    Joe H
    Dad ran a bunch of different electrical tachs on his distributor machine and found about the same thing as with the mechanicals. Not very many of them read the same. The top of the line Mallory's back in the early 80's read right on with his calibrated tach, we had three of them for different cars and all three read dead on. The off brands were all over the place.
    If you rig a way to hold the tach in the machine and short cable drive, you could compare the actual tach heads, by removing the gear train and long cables from the picture. This would confirm its the cables, gear train, or tach head thats causing the fluctuations.
    302GMC likes this.
  23. henryj1951
    henryj1951
    from USA
    ah HA--- so my 11,500 red tail tell needle tach drive was in all actuality only 9,500
    oh well
    It all MAKE's FOR A GQQD STORY...LOL
  24. Lost in the Fifties
    Lost in the Fifties
    Wasn't there a dist-drive and a generator-drive version tach that were calibrated differently?
  25. henryj1951
    henryj1951
    from USA
  26. ago
    ago
    from pgh. pa.
    Try taking your Jones tach apart and spray some WD-40 to loosen up the sticky grease.
  27. squirrel
    I thought about that, but didn't see an easy way to get the bezel back on after I probably destroy it during removal.
  28. falcongeorge
    falcongeorge
    from BC
    I had a sun Super Tach in my old V-8 pinto. I used to be able to make extra gas money by betting guys it would "rev past 8000",total ********, it was more like 7200 and 1000 rpm of overshoot, :eek::rolleyes: but most guys don't know that.;)
    henryj1951 likes this.
  29. falcongeorge
    falcongeorge
    from BC
    Yes, I have a '57 tach drive distributor, and a 1960/61 7000 rpm distributor drive tach.
  30. falcongeorge
    falcongeorge
    from BC
    This is what I suspect here too.
