Technical mechanical to hydraulic
Discussion in 'Traditional Hot Rods' started by cheeko55, Jan 2, 2018.
  1. cheeko55
    cheeko55
    Can anyone tell me what pedal ***embly I should use on my 36 5w coupe when changing from mechanical to hydraulic and still keeping it standard trans?
  2. johndee138
    johndee138
    from Atlanta GA
    If you use Early V8 Garage system you don’t need to change anything
    Mr Lacey’s system is well designed and allows you to use the stock pedals
    No welding,all bolt on and completely removable back to stock if you want to
    I have one of his system 1 setups for sale that I had to change out because of a transmission swap and the EV8Garage
    Parts didn’t work with the new ******
    Can’t say enough good things about this system though
    pm me for more info if you want to ask questions or take this master cylinder mounting bracketry off my hands since I can’t use it anymore
    bct likes this.
  3. joe1932
    joe1932
    from NY
    I think you'll find a 1939 pedal ***embly is what you are looking for. Joe
