Technical Meet Big L
Discussion in 'The Hokey Ass Message Board' started by grdra1, Oct 14, 2022.
  1. grdra1
    grdra1
    I just finished my louvre press today, named it Big L because its so dam heavy. I started with a set of dies purchased from local machinery shop and some heavy tube that were offcuts from a local factory, Paid $100 for 9 x 1metre lengths of 6 x 3 RHS with a 1/4 wall. I fabricated head unit from 3 inch solid and heavy wall pipe, I used an air over hydraulic setup from my pipe bender. During my first demo runs there was to much flex so I had to double up the tube on the spine - now its cuts through 1mm steel with ease, also put it on casters to make it easier to move around. A few pics Glen 20220828_175231.jpg 20220828_175237.jpg 20220828_175302.jpg 20220804_163856.jpg 20220830_171202.jpg 20220831_170224.jpg 20220831_170643.jpg 20220908_103332.jpg 20220908_104451.jpg 20220911_142554.jpg 20221014_171500.jpg 20221014_171506.jpg 20221014_171516.jpg 20221014_171540.jpg 20221014_171426.jpg
    nosford, treb11, ffr1222k and 24 others like this.
  2. Mr48chev
    That looks great, I'd be real shy of punching contaminated metal like that rusty stuff. That may damage your dies.
    alanp561, juan motime and Kiwi 4d like this.
  3. chevy57dude
    chevy57dude
  4. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    The efforts will surely pay off when it's time to vent.
    I wonder, how many punches do you plan for that Topolino?
    lothiandon1940 likes this.
  5. grdra1
    grdra1
    No punches for the Topolino as it may crack the fibergl***, I built this unit for my new 34 5 window - plans for Bonneville style build, may also fabricate a new louvered deck lid for my 31. Glen IMG_3637.jpg 438.JPG
  6. patsurf
    patsurf
    how many axe heads did YOU have to use?..
    alanp561 and Budget36 like this.
  7. Tim
    Tim
    from KCMO
    Looks great! So do the hot rods! Build threads on either?
  8. ClayMart
    ClayMart
    So would I be considered as just an incredible wimp if I suggested running a loop of safety cable thru the center of those two coil springs?
    :p
  9. 1-SHOT
    1-SHOT
    from Denton
    I also built my own louver press yes they do flex a lot. If you want a deeper louver turn the panel over and punch it on the same cut line and you will get this. 04B40507-0B19-4754-AFE7-933947A2C5EC_1_201_a.jpeg B9D578E8-7E3D-4C4C-B230-036D5851D0F0.jpeg
    Stogy, ffr1222k, alanp561 and 3 others like this.
  10. grdra1
    grdra1
    Probably a wimp (only joking), there is not that much tension on the extension springs to warrant safety wire. Glen
    Stogy likes this.
  11. ClayMart
    ClayMart
    From your pictures, I was only guessing that those springs were going to be under more stress. And you're correct in your ***umption. In the last 10 or 12 years I've become a bit more of a wimp, at least concerning my eyes.
    :rolleyes:
    Stogy and lothiandon1940 like this.
  12. grdra1
    grdra1
    I used Big L in anger for the first time today when I punched 74 louvers into my 34 bonnet, Big L performed flawlessly. A few pics, Glen 20221122_112106.jpg 20221122_123621.jpg 20221122_135515.jpg 20221122_164037.jpg 20221122_142523.jpg 20221122_142158.jpg
    Stogy, nosford, Chief 64 and 17 others like this.
  13. X38
    X38
    Were you nervous? :eek::D
    Stogy, alanp561 and lothiandon1940 like this.
  14. grdra1
    grdra1
    Yep, you bet I was, it went real smooth until my last 3 louvers when the bonnet would not fit in machine - throat depth not enough at wide end of bonnet, had to turn dies around, but it worked out ok. Glen
    Stogy, nosford, catdad49 and 3 others like this.
  15. X38
    X38
  16. Happydaze
    Happydaze
    Cracking job!
    I bet you'll be ac***ulating new friends at an alarming rate :).
    Chris
    Stogy, alanp561, chiro and 1 other person like this.
  17. lothiandon1940
    lothiandon1940
    Looks great! Good job.
    Stogy likes this.
  18. 41 GMC K-18
    41 GMC K-18
    Its really cool, when you make the tool yourself !
    Very impressive results !
    lothiandon1940, Stogy and alanp561 like this.
  19. BILL LUPIANO
    BILL LUPIANO
    from Canada
    Great work!
    Stogy likes this.
  20. guthriesmith
    guthriesmith
  21. grdra1
    grdra1
    Thanks guys, it was extremely rewarding when I finished this job, Big L done everything I needed with ease, as this was the first real test it could not have gone any easier. I am glad I went to the trouble of over engineering Big L. I was also happy with the design I used for the louvers, the outside louvers are angled a little more than the inside ones so they all line up facing the same direction. As this was my first ever attempt at this process, you bet I'm proud of myself. All the cool projects and knowledge I have gained from the build and tech threads on this awesome site have served as inspiration for my builds, weather its tools, machines or hotrods. Thanks again all involved, Glen
    Stogy, alanp561 and catdad49 like this.
  22. catdad49
    catdad49
  23. SPEC
    SPEC
    Great job.
    Stogy likes this.
  24. alanp561
    alanp561
    The answer to your question is yes, you would be considered an incredible wimp;). Grudgingly, because I really don't want to share the IW ***le with you, I think the cable loop is a good idea:cool:.
    lothiandon1940 and ClayMart like this.
