Mega simple tech tip on tire bustin at home....pics
Discussion in 'The Hokey Ass Message Board' started by Rocky, Nov 29, 2003.
  1. Rocky
    Rocky
    Classified Editor
    I can't believe I didn't figure this out sooner. Ever have a need to break the bead on a tire that's been rusted to the rim?
    Today I went over to check on my vast inventory of junk stored in my pickup box trailer to find the tire flat. Brought the tire home and found a bead leak from many years of moisture. I tried driving the Rocky Goodtime Van [tm] up on it to bust the bead to no avail. All I accomplished was to get the damn tire and wheel stuck under the van.
    Casting my eyes about, I spied a hunk of 1.5"X1.5" square tubing, cut at a 45 degree angle. I grabbed my favorite cut-off sledge and drove the pointy end between the tire and wheel...VIOLA! It was unbelievable how easily the two separated and the bead was broke in no time at all...
    I wire-brushed the rust off the rim and used a little left-over ford gasket cement to insure no more leaks. Tested it for bubbles with a spray bottle of soapy water and I was finished....1/2 hour total time for the repair.
  2. Rocky
    Rocky
    Classified Editor
    check it out
  3. Rocky
    Rocky
    Classified Editor
    Oops...next photo
  4. Unkl Ian
    Unkl Ian
    Eastwood will have those in the next sale flier. [​IMG]
  5. Gr8ballsofir
    Gr8ballsofir
    I just use my harbor freight 34.00 tire changer. but thats pretty cool. [​IMG]
  6. ray
    ray
    from colorado
    how well does the harbor freight one work?
    anyone got plans for a bead breaker? like one you would bolt to the floor...
    i hate spending money on getting tires mounted, and i doubt the drive on it trick will work with old cheater slicks...figured it would be a good thing to build/buy.
  7. Nixer
    Nixer
    rock...how did you hold the tire to the ground? tuck i had tried to do the same with some old tires from the yard, and had a hell of a time. was the tire completely deflated? what's up..what's up..huh? [​IMG]
  8. LIMEY
    LIMEY
    When i first started working in little out of town garage, i was taught to change tyres manually & we used to break the bead with a fookin great big hammer & a long lever that was heavier at one end with a 45 degree bend on it, that worked really well....the largest we ever did were Land Rover 16".
    There was a big old slide hammer designed for the job but wasn't as effective as the method simular to yours.
  9. any one who cuts and burns wood for heat, will have a splitting "wedge" that may also be useful for this [tire removal] too....... [​IMG]
  10. Levis Classic
    Levis Classic
    I know ROCKY quick make up a 100 or so and sell them on ebay a old tradition hot rod tool. You'll make a mint! It actually looks like a VERY useful tool - thanks for the tip!
  11. Rocky
    Rocky
    Classified Editor
    Bryan...I held the tire on the ground by standing on one side of it and working on the other. I also threatened the wussy tire with many 4 letter words and vulgar gestures. The neighbors were intrigued and amused.
  12. Rocky
    Rocky
    Classified Editor
    .......and yes, the tire was deflated before I started wailing on it.
  13. Rooster
    Rooster
    Didja try the bumperjack and a heavy truck method first? Is that old hat around here? Looks Way more manageable than a little wood wedge flying off in the opposite direction of the strike!
    Takin the valve center out is preferred Whenever you're dismountin tires Tokyo. They'll build pressure when ya compress to dismount and make it harder otherwise.
  14. Kustm52
    Kustm52
    Now someone show pictures the old "inflating with ether" explosion trick...! Rooster, I know you have done this....!
    Works every time though....if you live to tell about it.
    Brian
  15. Rooster
    Rooster
    Haha!!! These days when they get that obnoxiously difficult to mount I take em down to the tire shop, And Leave for an hour!!!
  16. Mike Paul
    Mike Paul
    Not to take anything away from Rockys idea but I saw that Harbor Frieght has got their tire changers on sale for 50% off or $34.99 and they work good, I just ordered 7 more for christmas presents and buddies at work. At that price it will pay for itself the first time you use it if you change a couple tires. Mike
    And no I don't work for Harbor Freight, just thought i'd let ya know
  17. 201
    201
    Best way to get the bead loose is to pour alittle diesel fuel around the rim edge.Let it soak a minute, use a truck tire hammer with the duck-bill type head on it. You have to hit the bead where it meets the rim and try to drive the duck bill under the rim edge.Its alot easier to do than it sounds.Had to take a tire apart on an 8-n tractor that was on there since the last ice age and the fuel and the hammer worked when tring to pry it down with a back hoe failed.
  18. burndup
    burndup
    from Norco, CA
    Theres also the tire-in-between-the-floorjack-and-midsize-car-frame trick, but it may or may not be nice to the tire...
  19. Bruce Lancaster
    Bruce Lancaster
    That's a great tool idea--but you were planning to reuse that tire, and didn't need to further remove it from the rim. I have a stack of 18" and 16" wires with petrified tires that were probably unuseable before I was born--anyone have a great method for completely removing dead tires without regard for future use? I have thought of hacksawing across the tires as a possible start--what really works? Quick, dirty, effective...
    Anything that doesn't involve several hours of wrestling.
