Hot Rods MEL engine questions
Discussion in 'The Hokey Ass Message Board' started by Winston Smith, Jul 21, 2026.
  1. rustymetal
    rustymetal
    hi wonder if somebody would know where to buy original over size piston or have a set thanks
  2. saltflats
    saltflats
    from Missouri
    Does Egg or I think that's the spelling for it have some. They seem to make a lot of odd ball engine pistons.
    bchctybob likes this.
  3. Winston Smith
    Winston Smith
    I did some hunting and found this in a 1958 Mercury.
    bchctybob and warhorseracing like this.
  4. squirrel
    is that the 383 FE engine?
  5. Winston Smith
    Winston Smith
    I think it's a 383, but is it FE or MEL? I couldn't get the door open to check any tags or anything.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
  7. Yup, with the fuel pump out front on the top as shown in the picture, it's a MEL not an FE.
  8. squirrel
    I knew something looked funny! thanks for the lesson
  9. TCTND
    TCTND
    Back in Honolulu in '64 my pal pulled one out of a Lincoln. My memory says 430 but who knows. It went into his boxy '58 pickup and he was king of the road; at least in his 19 yr old mind.
    bchctybob and saltflats like this.
  10. finn
    finn
    I think it was the Taunus , not the Taurus. The moniker was used by Ford Germany. The name comes from the Taunus mountain range in Germany.
    The Taurus was the FWD Ford Jelly bean fwd released for the US market in the 1980s.
    Different cars with similar, but different names and lineage.
    edit: oops, somebody beat me.
  11. Speedys Garage
    Speedys Garage
  12. Speedys Garage
    Speedys Garage
    I have some of these engines in my salvage yard I have a complete one out of the car message me the measurements you want and I will be happy to get them for you
  13. FrozenMerc
    FrozenMerc
    Egge and Kanter both sell MEL pistons of various sizes. However, they are generic flat top slugs that will significantly reduce your compression ratio and compromise the quench and chamber swirl causing a significant decrease in engine performance. This leaves you with two options, run the flat tops and add forced induction to take advantage of the low compression ratio, or have custom pistons made. Custom pistons have come down in price significantly over the years as CNC machining technology has improved.
    Kanter Flat Top:
    Custom MEL piston.
