Technical Mel-FE rocker shims
Discussion in 'The Hokey Ass Message Board' started by Dustin 257, Mar 19, 2023.
  1. Dustin 257
    Dustin 257
    from Dallas
    Anyone use rocker shims and have any problems with a FE or MEL. I can search and find plenty of people talking about using shims but no one comes back and talks about if they did or not. Got .100-.120 preload. Debating on adjustable rockers or shims. Working on my sons 410 Edsel
  2. Shims are used on FEs to correct rocker arm-to-valve geometry, not to adjust lifter preload, although they may help with that. For lifter preload with non-adjustable rockers custom-length pushrods are used. If you have the typical ball-and-cup pushrods, they can be a bit expensive. Lykins Motorsport offers a non-adjustable roller rocker that uses ball ends only, much cheaper and easier to get.
  3. saltflats
    saltflats
    from Missouri
    We had to make some for a FE we built with some BBM heads and Harland Sharp rockers. This was to correct the rocker arm geometry.
  4. Dustin 257
    Dustin 257
    from Dallas
    Thank you sir. Think I better just spend the money and get adjustable rockers and rods. I’ll watch the video in a bit. Do I once and be done with it right!
