Merc 4" Crank Damage
Discussion in 'The Hokey Ass Message Board' started by rgrhoward, Aug 20, 2012.
  1. rgrhoward
    rgrhoward
    Looking at picking up a few 8BA's from a fellow HAMBER. Also a 4" MERC Crank with a little damage. Please see the pics below, not a deal breaker if it can't be repaired but we are both curious.
    Fixable? or Yard art?
    Thanks in advance.
  2. hard to see , is that a crack in the first picture?
  3. 51 MERC-CT
    51 MERC-CT
    Was probably that way from the factory. Only one way to know for sure, have it balanced.
  4. Ford Guy
    Ford Guy
    looks like a crack to me:(
  5. rgrhoward
    rgrhoward
    I am guessing a crack = yard art.
  6. Flatheadfreddy
    Flatheadfreddy
    This is standard I think it is where the sprue was attached. I have several just like this.
    Freddy
  7. Bruce Lancaster
    Bruce Lancaster
    I think that is simply where casting sprue was broken away...this was a delicate operation done by an experience machinist with a sledge hammer.
    If worried, take that area down to shiny with a body grinder and examine surface, if real worried have it fluxed.
  8. Roger53
    Roger53
    It's the way there made if I was better at this puter thing I'd post some pic's.
  9. Bruce Lancaster
    Bruce Lancaster
    To translate...that is the bottom of the hole where melted Model T's and surplus Sherman tanks were poured into the hole. When the crank was pulled out, that site was a pillar of iron made so it was narrowest at that level and would so break right there. Someone then smacked the pillar with a hammer and sent it back to the foundry to be re-melted, and the carnk went off to be machined.
  10. #1 Kawboy
    #1 Kawboy
    from Fl
    Well put, Bruce.
  11. bobss396
    bobss396
    It looks like a parting plane in the casting. As long as it doesn't look it was caused by something broken internally (hammered to ****..), you should be okay.
    Bob
  12. Have it checked by a very qualified engine machinist.
    A. Magnafluz inspection for cracks.
    B. Check for straightness.
    C. Inspect and mic all journals.
    I have all the specs if you need them.
    I agree with the sprue theory.
  13. R Pope
    R Pope
    I have half a dozen Merc cranks and they all look like that. No worrys!
  14. brad2v
    brad2v
    I'll be damned! I'm the current owner of the aforementioned crank (although rgrhoward and I have a deal in the works). The crank was sold to me as NOS, I didn't look it over real well, got it home, saw that, and relegated it to the 'deal with later' pile. Very interesting. Oh well, buy high, sell low I always say.
  15. flatjack
    flatjack
    Yup, as stated, they all look that way.
  16. rgrhoward
    rgrhoward
    Thanks for all the info guys. Learn something new everyday.
    Only hope i can p*** on this knowledge someday.
  17. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    Looks fine to me unless there is a crack in there that didnt com through in the pics. Run it!
  18. Atwater Mike
    Atwater Mike
    If you're going to have it 'checked' or machined, have them shot peen it first. (then magna flux)
    I've always shot-peened 4" cranks. Ak Millar and Ray Brock were staunch advocates...
    I apprenticed in a Ford/Mercury shop.
    (never seen excessive breakage in flathead cranks, but there were lots of 'Y' blocks that broke 'em...239, 272, 292, 312...)
  19. 40FordGuy
    40FordGuy
    Easiest thing is take it to your local reliable machine, or balancing shop. They'll give you the straight poop.
    4TTRUK
