Technical Merc diff a 32
Discussion in 'Traditional Hot Rods' started by Kiwi 4d, Nov 24, 2013.
  1. Kiwi 4d
    Kiwi 4d
    What are the thoughts in using a 50 merc diff in a 32 with flathead and 5 spd. Haven't measured it as yet , but if we were to run it would it be better to use parallel or buggy spring? Or discard the idea and run a banjo diff with late axels? We are building a user friendly driver pickup.
  2. F-6Garagerat
    F-6Garagerat
    Isn't the 50 Merc still a banjo? I'm sure the width is different. The spring hangers might be longer and mess up the wheel base also, not sure. The 32 rear crossmember and spring are specific to each other. The spring puts the rear axle forward of the crossmember.
  3. khead47
    khead47
    48 was last year for banjo.
  4. V8 Bob
    V8 Bob
    The '49-'51 Mercury rear ends are a Dana integral carrier design. The biggest problem could be the overall wide width which I'm pretty sure is over 61". The parallel spring pads are also wide spaced, so new transverse or parallel spring mounts would have to be added for either choice.
    I'm running a '40 rear that was converted to slip-in 28 spline 9" axles/bearings, along with modern 10" Bendix brakes, and is a great way to upgrade a Ford banjo, IMO.
    :cool:
  5. F-6Garagerat
    F-6Garagerat
    So are they Dana 44's like a 48-50's truck?
  6. V8 Bob
    V8 Bob
    Yes, along with some '49-'56 station wagons, Couriers and sedan deliveries.
