Merc open drive questions (welding, parts)
Discussion in 'The Hokey Ass Message Board' started by rpu28, Nov 3, 2012.
  1. rpu28
    rpu28
    from Austin
    I'm converting my '39 Merc rear to open drive, but don't want to dis***emble it.
    For reasons unknown, early Merc banjo rear ends did not have a separable drive shaft - their drive shafts were basically a pinion gear with an eight-foot stem. The first pic shows the Merc with the torque tube removed and all but a foot of the drive shaft (1.125" diameter) cut off; the pinion gear is supported by a pair of tapered bearings, which are held in place by a nut and washer. The second pic shows the hat I'll use to contain a drive-shaft seal (and maybe another support bearing).
    Question #1: I'd like to weld a short section of spline onto the drive shaft near the hat, and then support a u-joint yoke on the spline with a nut. Does anyone know where I can get a suitable donor spline shaft, and a bolt-on yoke? (Note: I can machine threads onto a suitable splined shaft.)
    Question #2: What's the best way to weld the donor spline to the drive shaft stub? I'm thinking of making a drill bushing to drill a 1/2" center hole in the drive-shaft stub, turning an inch or so of the spline shaft to a press fit, and weld into some deep V's on the drive shaft and splined shaft.
    Question #3: The pinion shaft has two or three degrees slack in it (i.e. you can turn it a few degrees before it engages the ring gear) - is that too much, or normal for an old banjo?
    Question #4: Should I decide to rebuild the rear end, is there a comprehensive set of instructions available? I've seen bits and pieces of the process on the HAMB and in the rod mags, but never an A-to-Z write-up.
  2. BillWallace
    BillWallace
    You are lucky to have the shaft on the pinion. Find a 'u' joint & drive shaft that can fit when a spline is cut on the remaining shaft. Take the unit apart & go to a machine shop & have the shaft splined to the "u"joint.
  3. Kiwi 4d
    Kiwi 4d
    Is that "you don't want to dis***emble it ". Or " you don't really want to dis***emble it"
    As you will most likely have the 3.54 merc ratio gears the best way is to dis***emble it clean it up lop off the extra length merc shaft and machine a standard six spline into the pinion shaft. Not sure who else sell open drive adapters but speedway do.
    I cut off my own 39merc pinion shaft a few years ago and got it repsplined, but for a torque tube.
    I wouldn't think the pinion bearings would take to kindly to any welding.
  4. rpu28
    rpu28
    from Austin
    Still looking for a promising welding idea. Will weld slowly enough that pinion bearings are not affected.
    But suppose I did choose to spline the pinion shaft - does anyone know of a suitable machine shop in Central Texas?
    And does anyone have a complete set of banjo-rebuild instructions?
  5. rpu28
    rpu28
    from Austin
    HAZ should not be an issue if welded slowly with plenty of time to air-cool - also good ideas for keeping the coupling true.
    Still looking for the best idea on how to prepare for the weld, and part number(s) for the u-joint coupling.
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    One question???? How do you plan to get that bearing retainer/seal carier over a welded on coupling??? Re-splining sounds like a better fix.
  7. rpu28
    rpu28
    from Austin
    Not thinking of a coupling; welding withing the OD of the 1.125 shaft.
    Otherwise, would use o-rings and a two-piece retainer.
