Hot Rods Merc V8 Flywheel Question
Discussion in 'The Hokey Ass Message Board' started by movingviolation, May 2, 2017.
  1. movingviolation
    movingviolation
    Hey all,
    In the process of putting a 49-53 flathead mercury in between the rails of my 32 ch***is. I am looking to do so using a Muncie 4 speed..
    Question... is the Ford 239 flywheel the same as the Merc 255 fly wheel? I know the stroke is different, but i want to be 100% sure before i spend the money on a flywheel that accepts the GM10.5 clutch
    Thanks all
  2. 42merc
    42merc
    The difference between the Ford & Merc 8ba style flywheels is the clutch bolt pattern.
    Ford p***enger car '49-'53 would be 9 1/2" Long style pattern,
    Ford 1/2 ton '49-'53 truck would be either 10" Long or 11" long patterns.
    Mercury '49-'53 would be 10" Borg & Beck pattern.
    AVater likes this.
  3. movingviolation
    movingviolation
    So how would this play out if i buy the Centre Force flywheel that is drilled for the GM 10.5 clutch.. i should be fine?
  4. 42merc
    42merc
    If the Center Force flywheel fits the 8ba/Merc crank,you should be fine.
    Talk to Center Force & be sure.
  5. movingviolation
    movingviolation
    So is there a GM 10.5 Clutch and Pressure Plate that bolts to the stock Mercury V8 flywheel?
  6. 42merc
    42merc
    The standard Chevy 10 1/2" pressure plate from '60s-'70s & probably more will bolt to the '49-'53 Mercury flywheel.
  7. RICK R 44
    RICK R 44
    use the pick up flywheel and re drill it to match the pressure plate of your choice
