Projects Mercury Door Panels
Discussion in 'The Hokey Ass Message Board' started by jkluge, Feb 12, 2015.
  1. jkluge
    jkluge
    So I made some 1950 Mercury Door Panels, and I figured I would share.
    Started with this.
    Took and made some templates out of beer cases.
    Then I went and bought some Luan board, its like 3/16 to 1/4 inch thick furniture backing?
    Supposed to be mostly unaffected by water, but I put 8 mil plastic sheeting on the backside and wrapped the edges a bit in case there is some water coming in from the outside of the door.
    Then I went to Joann Fabric and got a few yards of Faux leather, and 1/2 "sewing batting" and cut the padding to fit the panel and glued and sewed that to the Faux leather. I bought the industrial white thread too. Then wrapped the Leather around the door panel.
    and Sew...
    Then we wrapped it around the door panel.
    IMG_20150207_235751.jpg IMG_20150208_000431.jpg IMG_20150208_000436.jpg IMG_20150208_000425.jpg
    Then painted my garnish Moldings. IMG_20150211_185237.jpg IMG_20150211_185249.jpg
    Then ended up with this. I think it turned out alright.
  2. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Came out well,nothing like D.I.Y . Looks good. How are you going to hold those to the doors though?
  3. jkluge
    jkluge
    I have some nice panhead stainless screws. Otherwise I have some screws with plastic caps. Going to see which looks better.
  4. Slopok
    Slopok
    Personally I think that will ruin an otherwise smooth look. Can you use some type of blind fastener or clip?
  5. AVater
    AVater
  6. J'st Wandering
    J'st Wandering
    You have some nice looking panels there; something that I have not tried to do myself. But this is the internet so I can be the keyboard expert. ;)
    The outside edge of the door has the holes for mounting the panels with those clips to put into the luan board. You could use your beer case pattern as a guide and poke around with an awl to find the holes. Just don't do what I would do and drill the holes for the clips and make a few holes in the vinyl by going too far.
    Again, nice job on the panels.
    Neal
  7. Model T1
    Model T1
    Nice. They sell original type wire clips that fit on the panel from the back in a small hole then just snap into the original door holes.
    I've heard of people using Velcro also. You don't want screws showing. I have used small chrome screws with little pop on covers on the corners for safety.
    You didn't say how you got the pleated look.
  8. jkluge
    jkluge
    We obtained the pleated look from sewing straight lines on just the faux leather and the foam, then attached to the luan board.
    I am going to look into those clips now that you mention it. Originally I thought it might look okay seeing a stainless screw but they do look real clean the way they are so I might not want to see that screw.
  9. 56premiere
    56premiere
    Use clips, I hate screws. Auveco 808 clips are straight in type, would be the best imho ,but probably require rolling the cover back to mark and install .
  10. Jim636
    Jim636
    from Wyandotte
    I have had little luck using velcro......
